Car doesn't go into gear when ON and running..
I have a GSR with a tsx engine.
WEll problem is it wont' go into gear when the car is on but when its off its fine.
when put in reverse when off and started it grinds like a ****. no gears work when its running car idling. I have an exedy stage 1 clutch I doudt its the clutch because its brand new it should be able to handle the torque..
I am thinking its the slave cylinder, going to change that see what happens!
any advise is welcomed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR »</TD></TR><TR><TD CLASS="quote">k24 swap i see. anything wrong with the shift linkage? did you just now start it up or has the swap ran fine before?</TD></TR></TABLE>
only problem I would say with the shift linkage is that there isn't one. But back to the OP, I would say its either your clutch or somethings wrong with the cables. Who did your swap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC »</TD></TR><TR><TD CLASS="quote">
only problem I would say with the shift linkage is that there isn't one. But back to the OP, I would say its either your clutch or somethings wrong with the cables. Who did your swap?</TD></TR></TABLE>
its not the cable. It was fine before. I did my swap. I am changing the clutch master cylinder. my clutch is brand new not sure if got fucked because It couldn't handle the torque.
hannslebo
May 6, 2009 04:37 AM
blue89hatch
Transmission & Drivetrain
Nov 24, 2008 11:14 PM
89civichatchback
13
Jul 9, 2003 11:23 AM
