bad vibration/ loud noise while turning right
there is a really bad vibration in the steering wheel and real loud noise only when my steering wheel is turned to the right...even a little such as changing lanes on the highway and ****
Take it in the shop or fix it yourself asap if you can you. You don't want to wait until your axle snaps into two pieces bacause it is going to be really hard to pull that thing out. Also, your car is not safe to drive as long you have that problem. Fix it bro
could be an axle
could be a wheel bearing
could be a tie rod
could be some play in the differential
why dont you lift your car off teh ground and check those out
could be a tie rod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biboy »</TD></TR><TR><TD CLASS="quote">Hey if you don't believe me go ahead drive your car until it breaks. Peace out!</TD></TR></TABLE>
didnt say i dont believe you but im just trying to be sure before i spend my hard earned money on an axle and that doesnt fix it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">could be an axle
could be a tie rod
why dont you lift your car off teh ground and check those out</TD></TR></TABLE>
ill get it on my trailor and bring it up to my school and get it on a lift and check it out i guess...thanks for the help
could be a tie rod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2392si »</TD></TR><TR><TD CLASS="quote">Does it sound like a click click? If so, the axle is gone. Should be more than 100.
its not a clicking its hard to explain...i checked the price of the axle and its 58.99 with a 35 core charge and it will only take like 20-30 minutes to replace the axle
</TD></TR></TABLE>its not a clicking its hard to explain...i checked the price of the axle and its 58.99 with a 35 core charge and it will only take like 20-30 minutes to replace the axle
an bad axle would more be like, a rough rough ride, if it was bad....turns shouldn't effect the axle to my knowledge, more speed then anything...just for future reference
REDBARON
14
May 24, 2001 07:25 PM
