Rough start up on 1990 Integra hot or cold.
Old Jul 21, 2007 | 08:20 PM
dohctor_B's Avatar
Default Rough start up on 1990 Integra hot or cold.
Hello everyone. I've got a 1990 Acura Integra and when I try to start it it really has a tough time starting. It will start as soon as i turn the ignition but will kind of "bog" or have a "heavy" start. It is hard to explain but it feels like something is clogged. It is not a problem right now because it still starts everytime but I think it might be in the winter months. Spark plugs are new, fuel pump primes as it should and all the fuel lines look ok. I am thinking fuel filter or fuel injectors? Any other suggestions or advice?
Edit: Idle is normal
Old Jul 21, 2007 | 09:30 PM
Sam92Teg's Avatar
Default Re: Rough start up on 1990 Integra hot or cold. (iSRT_Vtec)
Your concentrating on your fuel system, but you might need to check your ignition components; dist. cap, rotor, coil, ignitor, plug wires, and also your cam timing and ignition timing.
Old Jul 22, 2007 | 02:49 AM
SuckMyDOHC's Avatar
Default Re: Rough start up on 1990 Integra hot or cold. (Sam92Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sam92Teg &raquo;</TD></TR><TR><TD CLASS="quote">Your concentrating on your fuel system, but you might need to check your ignition components; dist. cap, rotor, coil, ignitor, plug wires, and also your cam timing and ignition timing.</TD></TR></TABLE>
Old Jul 22, 2007 | 02:19 PM
dohctor_B's Avatar
thanx alot, is there anyway to diagnosis which part it is other than a visual inspection? Like a voltmeter or something? I don't have a timing gun to check my timing tho
Old Jul 22, 2007 | 02:23 PM
SYNSEI's Avatar
If it doesnt start on hot days, chances are that it's your fuel relay.
Old Jul 22, 2007 | 09:41 PM
dohctor_B's Avatar
Default Re: Rough start up on 1990 Integra hot or cold. (SYNSEI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYNSEI &raquo;</TD></TR><TR><TD CLASS="quote">If it doesnt start on hot days, chances are that it's your fuel relay.</TD></TR></TABLE>
It always starts, it just hesitates and seems like its bogged down when it starts
boostmyda
Jul 2, 2010 07:40 PM
johnny090881
Jun 7, 2009 10:56 PM
gtec8285
Sep 21, 2008 01:33 AM
Atl_Monte
May 17, 2006 06:24 AM
dohc-nyne
Feb 2, 2004 12:44 AM
