Jdm b18c1 in a 91 hf crx
Old Jun 9, 2002 | 11:26 PM
hybrider's Avatar
Default Jdm b18c1 in a 91 hf crx
wanna get a 94-95 b18 and stick it in a 91 hf. Wondering if i will run into problems that wouldnt make the whole ordeal worth it. I just think it would be awesome to have a light *** car. And also gimme some et's on what u think i would run in the 1/4 with jun cams, cai, headers and 2 1/2" exhaust, light fly and clutch. I believe the jdm b18c1 has 180 hp stock. Thnx in advance (by the way this is not hybrider93 but his friend whos sick of his 50000 lb eclipse).
Old Jun 10, 2002 | 09:43 AM
hybrider's Avatar
Default Re: Jdm b18c1 in a 91 hf crx (hybrider93)
a little bump for my friend
now i dont know much about the b18c swap into a crx, but i believe he will run with clearance issues correct? how bad? will he need to move the mounts?
Old Jun 21, 2002 | 06:59 AM
hybridreams's Avatar
bump
I'm putting a C1 into an '88 CRX shortly as well
Old Jun 21, 2002 | 04:28 PM
1st-hybrid's Avatar
I just finished my swap, I put a b18c1 in to my 88 hf. I'm taking it to put on an exhaust tomorrow(i hope). The only problems that you might have is just getting all the parts you need. It takes a bit of time to plan everything out, and get all the pieces. As for times, I'm not sure, but I hope to be in the low 14's when I'm done, we'll see.
As far as clearance issues, I'm using HCP mounts, courtesy of blown90hatch. The engine sits a bit lower than stock, and when I put my g/c's in there I don't think I'll be able to go as low as I wanted, but hey, at least I'll have a b18c
[Modified by 1st-hybrid, 2:30 AM 6/22/2002]
Old Jun 21, 2002 | 08:44 PM
DA-MAX's Avatar
Default Re: Jdm b18c1 in a 91 hf crx (1st-hybrid)
what about the B18s hydro tranny compared to the CRXs cable tranny??? I know the swap is obviously possible, but is it anymore difficult because of the difference in trannys or is there an "easy" way around this?? I'm planning on doing the B16a1 swap(with cable tranny) into a 91 HF, but was just wondering how the B18 works out...
Old Jun 23, 2002 | 12:07 PM
bryant's Avatar
Default Re: Jdm b18c1 in a 91 hf crx (DA-MAX)
Just slap the Cable tranny on the B18. As for problems, only thing i could think of would be some slight clearance issues. But should swap in just like any other B-series swap.
Old Jun 24, 2002 | 08:04 PM
1st-hybrid's Avatar
I just used an older cable tranny. As far as clearance issues, it fits fine, you just have to wiggle it in just a little bit.
Jake8493
Jan 27, 2014 01:16 PM
vtecn8ive
Jul 24, 2008 12:17 AM
wilhfcrx
Mar 17, 2008 04:36 AM
tolnep
Jun 1, 2004 06:37 AM
.Ryan
May 13, 2003 12:55 AM
