Aluminum tig welding.....
Old Jul 21, 2007 | 05:36 PM
Blown90hatcH's Avatar
Default Aluminum tig welding.....
Second time welding tig/aluminum. Tell me what you guys think of my flat stock welding. I am still haven't got time to try the round tube yet, but what advice can you give on turning the tube, having someone turn it, or stop welding...turn it...start again...etc? Syncrowave 200, 1/16 pure tungsten-green, 3/32 5356 filler.
Old Jul 21, 2007 | 06:30 PM
ebydrc's Avatar
Banned
i normaly just tack the pipe in place. when i tack the tube i lay a bead about 1/2 long, stop turn the tube and tack again. i do that in three places, and then weld the rest. having two people to weld on tube isnt the most eff. and you need to work on the consistency of you beads, you need to add the filler at a rythem (sp?)
Old Jul 21, 2007 | 06:43 PM
mrbsponge's Avatar
jason were those done on flat or vertically?
lookin pretty good for just getting that welder mang!
did some HEAVY tig'n at work today, got a new flexi-torch as well
Old Jul 21, 2007 | 08:16 PM
TurboSI56's Avatar
Default Re: Aluminum tig welding..... (Blown90hatcH)
I've always had issues with 1/16th tungsten above 120ish amps, and would definitely recommend 3/32 Red or Green tungsten. Also, I've found it to be helpful to sharpen your tungsten (like you were welding steel) and ball it on DC Positive (at around 60ish amps) it creates a smaller ball, and allows more gas to flow around, and overall a more stable arc.
Old Jul 22, 2007 | 12:40 PM
Default Re: (ebydrc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebydrc &raquo;</TD></TR><TR><TD CLASS="quote">i normaly just tack the pipe in place. when i tack the tube i lay a bead about 1/2 long, stop turn the tube and tack again. i do that in three places, and then weld the rest. having two people to weld on tube isnt the most eff. and you need to work on the consistency of you beads, you need to add the filler at a rythem (sp?)</TD></TR></TABLE>
Thanks man. I was thinking more of having someone or something turn the tube while I welded it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">jason were those done on flat or vertically?
lookin pretty good for just getting that welder mang!</TD></TR></TABLE>
Two flat and one vertically. Still trying to get confortable on the vertical position.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSI56 &raquo;</TD></TR><TR><TD CLASS="quote">I've always had issues with 1/16th tungsten above 120ish amps, and would definitely recommend 3/32 Red or Green tungsten. Also, I've found it to be helpful to sharpen your tungsten (like you were welding steel) and ball it on DC Positive (at around 60ish amps) it creates a smaller ball, and allows more gas to flow around, and overall a more stable arc. </TD></TR></TABLE>
Thanks man! Keep them coming.
Old Jul 22, 2007 | 02:55 PM
ebydrc's Avatar
Banned
i use 3/32 pure and 3/32 filler..
Vintech
Welding / Fabrication
19
Jan 1, 2008 12:05 PM
weiRtech
21
Jun 1, 2007 06:05 AM
MindLess311
Jan 21, 2007 04:48 PM
ekim952522000
Mar 3, 2006 08:58 PM
madcrossover
Feb 27, 2006 09:20 AM
