94 civic all lights on even when car is off.
Old Jul 21, 2007 | 04:31 PM
labtec's Avatar
Default 94 civic all lights on even when car is off.
like the question states when i put my wire harness back in and connected the battery all of the lights are on constantly with no key.
did a relay go out? possibly a ground somewhere?
has anyone experienced a problem like this before? howd you get around it thanks!
*edit
after some searching ive found out that it might be the fillament in the bulbs.
i think i might have plugged something in incorrectly when i took the dash out, but i dont see what kind of connection would lead to this outcome. any ideas?
checked all of the underdash/underhood fuses and those are fine.
Modified by labtec at 7:47 PM 7/21/2007
Old Jul 21, 2007 | 06:52 PM
labtec's Avatar
Default Re: 94 civic all lights on even when car is off. (labtec)
bump for the help
*the wire harness is completly stock EXCEPT the A/C extention has been removed, the windshield wiper resivor harness clip has been cut, and the cigarette lighter has been as well.
so my guess is a incorrect connection behind the dash/fusebox somewhere
Old Jul 21, 2007 | 09:33 PM
labtec's Avatar
BUMP & UPDATE
i removed the headlight/turn signal switch and the lights went off. i do'nt want to say that it's a bad switch just yet. i'm going to use a multimeter to try and determine which one of C431's (harness clip # for the switch located on the left side of the steering column) 7 wires might possibly be faulty.
amjam123
Audio / Security / Video
Jul 3, 2008 10:52 AM
Ghetto Civic HX
Nov 14, 2007 07:53 AM
flyingduck04
27
Dec 30, 2006 03:52 PM
Econo'Box
Nov 6, 2004 06:39 PM
brent_G
21
May 2, 2003 07:06 PM
