b16 engine bearings
Old Jul 21, 2007 | 02:00 PM
Cheefed's Avatar
Default b16 engine bearings
hi all, im building my first engine which is a b16. anyone know of a website that sells honda oem engine bearings. i'm just unsure about using ACL bearings as they probably aren't within clearance specs. i am also planing on getting a size bigger, because this is going to be a turbo build.
thanks
Old Jul 21, 2007 | 02:10 PM
GSaura's Avatar
Default Re: b16 engine bearings (Cheefed)
http://www.slhondaparts.com <--- bearings under 99-00 si DOHC crankshaft/piston section
http://www.acuraoemparts.com
http://www.hondapartsdeals.com might have bearings
I usually use one of those sites if I'm buying a bunch of crap.
You don't want to get a size bigger especially if you're going turbo. Looser clearances are generally used on higher power motors. If you get larger bearings, the crank/main and crank/rod interface will heat up, wear out, bind, and your crank is done for. Take time with the build and enjoy it.
Old Jul 22, 2007 | 01:16 AM
Cheefed's Avatar
Default Re: b16 engine bearings (GSaura)
awesome, Thanks
DlyDrvr
Feb 23, 2012 05:24 AM
sanjay2
Jun 14, 2010 07:21 AM
ek_civic96
Oct 24, 2008 05:40 AM
JayDM-hatch
Jan 23, 2008 09:27 PM
TheSwift1
Nov 12, 2002 08:12 AM
