High idle b18 swap crx
Old Jul 21, 2007 | 12:14 PM
MugenCRX89's Avatar
Default High idle b18 swap crx
So i fired up my crx for the first time , it has the b18 swap in it and it idles around 3000-4000 rpm. what could be the problem?
Old Aug 13, 2007 | 06:53 PM
BIG_T's Avatar
Default Re: High idle b18 swap crx (MugenCRX89)
are you getting any codes?? ur throttle cable could be to short or ur throttle cable bracket wont let it adjust to lower the idle anymore. could also be iacv
Old Jan 16, 2008 | 02:19 PM
haroldthefly91crx's Avatar
Default Re: High idle b18 swap crx (BIG_T)
BIG vacume leak
same thing happened to me, my problem was that i was missing a part on the intake manifold,
not sure what its called but its under the throttle body, it has 2 coolant lines going into it from the head,
if you are missing it there will be 2 holes where the air is comming in causing the high idle,
ill try and find a pic of it
Old Jan 16, 2008 | 02:56 PM
DeadReady's Avatar
check the vacuum hoses first. pretty sure its something simple
Old Feb 28, 2008 | 04:29 PM
fin781's Avatar
Default Re: (DeadReady)
check intake manifold gasket, i had the same problem on my d16
freddy chavez
Apr 8, 2013 07:40 AM
chope045
Oct 24, 2011 04:12 PM
busha61067
Feb 13, 2010 09:00 AM
civic dx
Aug 25, 2004 03:10 PM
QWKPHKR
Oct 8, 2002 06:37 PM
