Taking Backseats off help
Old Jul 21, 2007 | 11:15 AM
beigemonkey's Avatar
Default Taking Backseats off help
I have a 2003 4door accord lx 4cyl and theres so odor coming under the backseat. I want to take the backseats off to see wassup. Can someone point me to the right direction and is it hard to do? I don't need to take the entire thing off JUST the right side.
any help is appreciated.
Old Jul 21, 2007 | 11:52 AM
Twistedframe's Avatar
Default Re: Taking Backseats off help (beigemonkey)
Not sure how the '03 model is set up, but I imagine that it's not changed too much since '97, as far as the mounting system. You'll have to remove the seat backs first. Start by folding them down and looking on the sides or back at the very bottom where the pivot point is at. There should be some screws holding them onto the brackets. Remove those, then the seat backs should come out. Afterwards, look behind the lower seat cusion, and you will see another bolt holding down a bracket that extends to the seat itself. Remove that, and pull from the rear of the cusion, up and towards you. There will probably be two metal loops holding onto the front edge of the seat, that are stuck through holes in the chassis, but just work with it and it will come out.
Old Jul 21, 2007 | 12:15 PM
thanks I'll give it a go in a little bit.
Old Jul 21, 2007 | 04:55 PM
hondadude's Avatar
where the seat and back meet, spread your crack [LOL ] and look for a 10mm bolt that holds a tab. Remove that bolt and you should be able to fold the seat cushion up and foward.
jgrif08
Oct 23, 2006 06:08 PM
skingfreak
Apr 30, 2006 08:23 AM
Ckleijne
Oct 29, 2005 11:15 PM
1hotintegra
Acura TL, RL & ZDX
Apr 14, 2005 02:13 AM
skinnyminnie1016
Feb 22, 2005 03:47 PM
