truck bedding coating for ebay pedals
Old Jul 21, 2007 | 09:56 AM
tekstyle's Avatar
Default truck bedding coating for ebay pedals
i guess this applies to all swiss cheese aluminum pedal covers ebay or not ebay. I have been owning a set of these pedals and i notice that when the sole of my shoes are wet, these pedals seems to be very slippery. I had the idea of spraying them with truck bedding coating (splatter paint) to give it a vinyl polymer texture to enhance it's grip. the color will be black obviously, but that's not a concern since i want it to look kind of stock anyways. has anyone have experience using these spray? dupli-color sells one, but i don't know how long they will hold up before they rub off.
Modified by tekstyle at 8:44 PM 7/21/2007
Old Jul 21, 2007 | 11:44 AM
tekstyle's Avatar
Default Re: truck bedding coating for ebay pedals (tekstyle)
anyone?
Old Jul 21, 2007 | 08:12 PM
Leo C's Avatar
Night Owl
griptape
Old Jul 22, 2007 | 01:37 PM
DangerMouse's Avatar
Default Re: truck bedding coating for ebay pedals (Leo C.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo C. &raquo;</TD></TR><TR><TD CLASS="quote">griptape </TD></TR></TABLE>
Old Jul 23, 2007 | 12:19 PM
tekstyle's Avatar
Default Re: truck bedding coating for ebay pedals (Turbo_D)
how well does grip tape stick on? i dont want it to peel after 5 years. has anyone done this before? thanks!
Old Jul 23, 2007 | 12:26 PM
WihaSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">...but that's not a concern since i want it to look kind of stock anyways.</TD></TR></TABLE>
Leave it stock then
Old Jul 23, 2007 | 07:40 PM
aarontrini85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tekstyle &raquo;</TD></TR><TR><TD CLASS="quote">how well does grip tape stick on? i dont want it to peel after 5 years. has anyone done this before? thanks!</TD></TR></TABLE>
i did grip tape on my tc for 3 years no issues and did it on my crx to for 6 months no issues just through out the stock plastic covers for the clutch and brake and grip tape on them then grip tape over the stock plastic gas pedal
grip tape ftw
Modified by aarontrini85 at 10:54 PM 7/23/2007
Old Jul 23, 2007 | 07:52 PM
b18civicHx's Avatar
Default Re: truck bedding coating for ebay pedals (aarontrini85)
line-x!
Old Jul 23, 2007 | 11:34 PM
bobjohnson's Avatar
5 years? Most stock grip doesnt even last that long, especially if your problem is with wet feet... It will stick no problem, but the grip will probably wear down after a couple of years. Id say just use some grip tape, or if you dont want that, you could probably use some rubber rocker guard, that stuff will come out grippy, but it might not look so great. Rocker guard will last longer than grip tape.
Old Jul 24, 2007 | 04:33 AM
Default Re: truck bedding coating for ebay pedals (bobjohnson)
/\ there is no where near as much friction here as there is when skateboarding so it tends to last alot longer
Old Jul 24, 2007 | 03:44 PM
tekstyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">/\ there is no where near as much friction here as there is when skateboarding so it tends to last alot longer </TD></TR></TABLE>
^ you make a valid point i must say.
never heard of line-x. will look it up online later tonight.
i want the stock look, but i want a longer gas pedal. i did put pedals on my car and i can heel toe a lot better. i find it very hard to do it in a scion TC ( which i am installing the pedals in btw) because the pedal is shorter then the brake.
Old Jul 24, 2007 | 04:10 PM
i want the stock look, but i want a longer gas pedal. i did put pedals on my car and i can heel toe a lot better. i find it very hard to do it in a scion TC ( which i am installing the pedals in btw) because the pedal is shorter then the brake.</TD></TR></TABLE>
you meen how its ressesed or what ever yeah it sucks that electronic controlled t/b blows
Old Jul 26, 2007 | 09:00 AM
tekstyle's Avatar
Default Re: truck bedding coating for ebay pedals (b18civicHx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18civicHx &raquo;</TD></TR><TR><TD CLASS="quote">line-x! </TD></TR></TABLE>
i looked up this stuff and it seems that they only do it professionally, not from a rattle can. i do not want to pay someone to spray pedals. however, this seems like the best route to go and is one of the most recommended on the truck and jeep forums.
ek4shizzle
Audio / Security / Video
12
Jun 26, 2008 08:47 PM
whatan00b
Jul 1, 2007 10:46 PM
P@@RB@Y
17
Oct 28, 2005 12:59 PM
sohctodohc
Suspension & Brakes
Oct 24, 2005 08:12 AM
Mikeyslude
Sep 9, 2003 02:35 PM
