Sounds like axle popped out, but it didn't! Grinding noise, car wont drive, wont move
So check out this guys post:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i got a new h22 tranny for my eg cuz i thought i may have messed my diff up and put new tranny in and does exact same thing...when put in gear and clutch engaged it makes a very loud grinding noise(not like a gear grinding) and the tach goes up like as if it were in gear and the car was moving, ive replaced axles and intermediate shaft and still makes the loud noise and car does not move, axles are seated perfectly in the diff.....cannot figure this out and neither can anyone i know....help would be great </TD></TR></TABLE>
Nothing came of the thread I quoted, but I have the exact same problem. I replaced my transmission to get rid of the grinding noise (it sounds like an axle fell out of a tranny and the splines are grinding). The grinding noise is gear dependent, it goes faster in higher gears.
I replaced the tranny, so that is not the issue. I checked the axles and half shaft and didn't see anything wrong. After the tranny, you have axles/halfshaft/hub assy.
What could be creating this awful spline/grinding noise?
The universal joint on the drivers axle is muck. Gator stage 2 FTL. Hopefully there is some form of warrenty on this thing.
The axle/halfshaft assy. was spinning but not the hub/splined side of the universal joint.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane »</TD></TR><TR><TD CLASS="quote">The universal joint on the drivers axle is muck. Gator stage 2 FTL. Hopefully there is some form of warrenty on this thing.
I was about to mention this...Had it happen to me while driving on the highway at about 100 mph. Axle inboard shaft seperated from the axle shaft itself and got stuck.
</TD></TR></TABLE>I was about to mention this...Had it happen to me while driving on the highway at about 100 mph. Axle inboard shaft seperated from the axle shaft itself and got stuck.
mdwood2
Jul 8, 2012 03:13 PM
Sinner
Apr 7, 2004 12:56 PM
ninetyfourgsr
Feb 6, 2004 08:32 AM
TheHater
15
Jan 22, 2003 06:46 PM
