HELP! GSR Rear Disk Conversion Question ! HELP!
Old Jul 21, 2007 | 08:05 AM
Uncle Jesse's Avatar
Default HELP! GSR Rear Disk Conversion Question ! HELP!
Hey everyone,
I have a question if anyone could answer.
I have a 97 civic hatchback, I just completed a rear disk conversion from a 94-01 Integra GSR. Now, I'm wondering which e-brake cable I would use with this conversion in order for the e-brake to work correct.
Civic or Integra, I wonder if the length of the chassis matters in this situation.
Thank in advance guys !
Old Jul 21, 2007 | 03:26 PM
Default Re: HELP! GSR Rear Disk Conversion Question ! HELP! (jdm_8)
anyone? no information on this?
Old Jul 21, 2007 | 04:04 PM
BlueIntegraBoy's Avatar
Integra
You can't use drum cables on disks.
Old Jul 21, 2007 | 04:12 PM
gsxr1k05's Avatar
Default Re: HELP! GSR Rear Disk Conversion Question ! HELP! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Integra
You can't use drum cables on disks.</TD></TR></TABLE>
i dont know if it is true for the 92-95 civics, but i know with the 90-91 crx si, they had rear disc and you were supposed to use the cables from that. the integra ones would work, but they are a little long.. you have to crank the hell out of the adjuster.
i would assume the same here.
Old Jul 21, 2007 | 06:10 PM
CapnKrunch's Avatar
Default Re: HELP! GSR Rear Disk Conversion Question ! HELP! (gsxr1k05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 &raquo;</TD></TR><TR><TD CLASS="quote">
i would assume the same here. </TD></TR></TABLE>
yeah your correct too, the integra ones require some modification. the other option of cables would be the 00 civic si cables and would require no modification.
Old Jul 21, 2007 | 07:01 PM
Z3120's Avatar
CapnKrunch is right. You should use the 99-00 civic si brake cables.
Old Jul 21, 2007 | 07:22 PM
24TEN's Avatar
PHANTOM MENACE
90-01 Integra/88-00 Civic ebrake cables will work as long as they are from a disc set up. The only reason why the CRX is specific is because of the car's overall length.
Old Jul 21, 2007 | 08:17 PM
gsxr1k05's Avatar
Default Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN &raquo;</TD></TR><TR><TD CLASS="quote">90-01 Integra/88-00 Civic ebrake cables will work as long as they are from a disc set up. The only reason why the CRX is specific is because of the car's overall length.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch &raquo;</TD></TR><TR><TD CLASS="quote">
yeah your correct too, the integra ones require some modification. the other option of cables would be the 00 civic si cables and would require no modification.</TD></TR></TABLE>
thanks for keeping me straight.. im new to the 92-95 civic scene, but have done lots with crx's
Old Jul 23, 2007 | 02:16 PM
Default Re: (Z3120)
Thanks to everyone, Greatly Appreciated !
dj theoretic
Jun 3, 2008 10:24 AM
DohctorVtec
Oct 11, 2007 04:25 PM
astroxtc
Jan 11, 2006 12:43 PM
jdmscg
Nov 3, 2004 05:01 PM
