HELP! GSR Rear Disk Conversion Question ! HELP!
Hey everyone,
I have a question if anyone could answer.
I have a 97 civic hatchback, I just completed a rear disk conversion from a 94-01 Integra GSR. Now, I'm wondering which e-brake cable I would use with this conversion in order for the e-brake to work correct.
Civic or Integra, I wonder if the length of the chassis matters in this situation.
Thank in advance guys !
Re: HELP! GSR Rear Disk Conversion Question ! HELP! (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Integra
You can't use drum cables on disks.</TD></TR></TABLE>
i dont know if it is true for the 92-95 civics, but i know with the 90-91 crx si, they had rear disc and you were supposed to use the cables from that. the integra ones would work, but they are a little long.. you have to crank the hell out of the adjuster.
i would assume the same here.
Re: HELP! GSR Rear Disk Conversion Question ! HELP! (gsxr1k05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsxr1k05 »</TD></TR><TR><TD CLASS="quote">
i would assume the same here. </TD></TR></TABLE>
yeah your correct too, the integra ones require some modification. the other option of cables would be the 00 civic si cables and would require no modification.
Re: (24TEN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24TEN »</TD></TR><TR><TD CLASS="quote">90-01 Integra/88-00 Civic ebrake cables will work as long as they are from a disc set up. The only reason why the CRX is specific is because of the car's overall length.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CapnKrunch »</TD></TR><TR><TD CLASS="quote">
yeah your correct too, the integra ones require some modification. the other option of cables would be the 00 civic si cables and would require no modification.</TD></TR></TABLE>
thanks for keeping me straight.. im new to the 92-95 civic scene, but have done lots with crx's
dj theoretic
06-03-2008 10:24 AM
astroxtc
01-11-2006 12:43 PM
