ep3 07 wheel conversion?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">That's a lot of work just to add a set of boat-anchor 07 Si wheels. Not to mention the 5-lug setup itself weighs more than the 4-lug.</TD></TR></TABLE>
I've been interested in swapping to a 5 lug setup on my '02 Si so that I could share a set of track wheels with my ITR. I assume it's more than just the hubs that would need to be changed?
I just wanted to be able to mount five lug wheels on my 02. I really not that concerned about the braking upgrade or the weight of the wheel. EP3's are slow anyway.I haven't seen anyone with 06/07 si wheels on an 02/03.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanplayjoint »</TD></TR><TR><TD CLASS="quote">I just wanted to be able to mount five lug wheels on my 02. I really not that concerned about the braking upgrade or the weight of the wheel. EP3's are slow anyway.I haven't seen anyone with 06/07 si wheels on an 02/03.
There are SO many more wheel choices for a 4x100 wheel, why would you want to do that?
whatever i was just pointing you towards someone that has done a 5 lug conversion. but here is a guy on ephatch.com that did an rsx 5 lug conversion with somewhat of a write up
http://www.ephatch.com/forum/s...rsion
EPHatch has been having a lot of problems the past week or two... Basically when my friend did her Type-S 5lug swap she had to get the following stuff:
Type-S Axles, 02-03 RSX Type-S 5lug swap, Lower Ball Joint, new BOots from Honda $2 each, you can use the EP3 brake lines, new cotter pins, new brake fluid, new axle grease, and you also could use some PB blaster
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidNit »</TD></TR><TR><TD CLASS="quote">EPHatch has been having a lot of problems the past week or two... Basically when my friend did her Type-S 5lug swap she had to get the following stuff:
I know that you can use parts from the base model RSX, then you do not need different axles.
</TD></TR></TABLE>I know that you can use parts from the base model RSX, then you do not need different axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
I know that you can use parts from the base model RSX, then you do not need different axles.</TD></TR></TABLE>
You're correct, I apologize for not making that clear in my post. My friend purchased the Type-S axles, but you can use the base RSX ones as they are 5lug too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">i was just browsing mugen wheels on kingmotorsports and now i want a 5 lug swap
That's another reason I'd like to do the swap - my bronze MF10s would look sweet on a white EP
</TD></TR></TABLE>That's another reason I'd like to do the swap - my bronze MF10s would look sweet on a white EP
If you just want the 5 lug setup you can get the hubs and rotors from the 04-05 ep3 and throw those on. I believe everything else is the same. But rsx or ep 5 lug will still require spacers to run the 07 si wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthep3 »</TD></TR><TR><TD CLASS="quote">If you just want the 5 lug setup you can get the hubs and rotors from the 04-05 ep3 and throw those on. I believe everything else is the same. But rsx or ep 5 lug will still require spacers to run the 07 si wheels.</TD></TR></TABLE>
finding an 04/05 5 lug setup would be really hard because not many people swap that out unless they are doing a type r conversion which is rare too. getting the parts from a dealer would cost way too much plus if you are gonna do all that work than why not just do a type s swap and get the advantage of bigger rotors in the front at a much cheaper price than doing the 04/05 si 5 lug swap.
finding an 04/05 5 lug setup would be really hard because not many people swap that out unless they are doing a type r conversion which is rare too. getting the parts from a dealer would cost way too much plus if you are gonna do all that work than why not just do a type s swap and get the advantage of bigger rotors in the front at a much cheaper price than doing the 04/05 si 5 lug swap.</TD></TR></TABLE>
truth...
truth...
you can swap just the hub/knuckle from a 5 lug its not that hard and if you want to go all out go with type-s suspension
i did it and i love it
here it is
heres the front done
finished product
i love how the bigger front rotor looks in the wheels
plus stopping power
here it is
finished product
plus stopping power
i wanted to rip off my neighbors odyssey emblem and put it on my car but i've never talked to them and i'm sure they'd figure it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by parce85 »</TD></TR><TR><TD CLASS="quote">you can swap just the hub/knuckle from a 5 lug its not that hard and if you want to go all out go with type-s suspension</TD></TR></TABLE>
how much did that trunk load cost you, minus the struts?
Mike,
Going 5 lug was the best thing I ever did to the EP3 along with suspension. I recommend the TYPE-S lugs over the DC5R setup though. It's more practical and never had an issue with braking on track with Cobalt pads.
-Victor
-Victor
i paid $500 with axles front struts and calipers rotors
complete package oh and wheels too which are for sale now 02 rsx-s $140 obo
and yeah me and friends always made fun of them by calling them "Odyssey Sports" "Odyssey coupes"
