Rear camber bolts same 1.25 thread pitch on 92-95 as 96-00?
Old Jul 21, 2007 | 05:13 AM
Fuster_Cluck's Avatar
Default Rear camber bolts same 1.25 thread pitch on 92-95 as 96-00?
I need to get new hardware for the rear of my EG. I really don't want to spend $2.50 per bolt when I can get 10.9 grade for $1 per bolt. Plus with the 40mm I can throw a washer underneath for some camber correction
Is the thread pitch still 1.25 on the 92-95's?
If so, M10 X 1.25 40mm will be what is needed
Thanks for any feedback.
Old Jul 21, 2007 | 05:36 AM
Bense's Avatar
95% of the M10 bolts that honda uses is 1.25. I've seen a few m10-1.5 but thats mostly on the shift ****.
It's safe to assume that anything that's load bearing is going to be 1.25 thread pitch. Just get some grade 12.9 allen head cap screws from mcmaster. it will be like 5 bucks for 10 of them and then you can add it to your mod list of "things that don't make a difference but helps me feel better about my car"
Old Jul 21, 2007 | 05:40 AM
sicones's Avatar
Default Re: (Bense)
allen head
Old Jul 21, 2007 | 05:48 AM
Bense's Avatar
Default Re: (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">allen head </TD></TR></TABLE>
nothing wrong with allen head if you have the right tools for the jerob
Old Jul 22, 2007 | 04:25 AM
I ended up getting Grade 8.8 from the local Napa for $1.19 each. Should do the job and have a nice pretty red coating on them
Thanks for the feedback
2LEM1
Suspension & Brakes
May 13, 2012 10:13 AM
em1_mark
Mar 4, 2004 03:36 PM
lil k
May 19, 2003 12:22 AM
Fuster_Cluck
Jul 10, 2002 10:35 AM
fcuked
10
May 8, 2002 09:18 PM
