AEM Uego Wideband 6 in 1 Gauge | AEM Tru-Boost Controller - In stock ready to ship!
Old Jul 20, 2007 | 11:17 PM
phearable's Avatar
Default AEM Uego Wideband 6 in 1 Gauge | AEM Tru-Boost Controller - In stock ready to ship!
<FONT COLOR="blue"><FONT SIZE="4">AEM Uego Wideband 6 in 1 Gauge System</FONT></FONT>
<FONT SIZE="2">
Phearable.net utilizes aem uego products for all tuning services & in personal/customer vehicles.
Description:
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Key Features:
- Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
- Does not oscillate AFR reading like narrow band sensors
- Easy to install & No laptop required for monitoring!
- Bosch sensor included
- Accurate to 0.1 AFR
- Reads in AFR or Lambda via a switch in back of gauge housing
- 24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
- Integrated three-digit display reveals AFR or Lambda in real time
- User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
- Serial data stream included for output of AFR (RS 232)
- Works with AEM EMS, Hondata, Ectune, Neptune, Uberdata & more!
Recommended Wide Open Throttle Target Air Fuel Ratios On 91-93 Octane Vehicles:
All motor vehicles: 12.9-13.4:1 (Full Throttle)
Forced Induction Vehicles: 11.2-12.0:1 (Full Throttle)
Partial Throttle/Idle: 15.5:1 (Light Throttle) 14.7-13.6:1 (Partial to Mid Throttle)
There are many small variables involved in targeting your air/fuel ratios, the main idea is to ensure you are not running too rich or lean & making the safest & best power possible due to maintaining a proper amount of fuel to your motor at all times.
How hard is the AEM Uego to install?:
The AEM Uego is very easy to install.
The system only uses 4 wires: 12v, Ground, Signal, Serial
To datalog the 0-5 volt output you simply use the white wire in the harness with which ever system you are using i.e. hondata.
How long will it take for me to receive my order?:
Your order will be shipped within 1-3 business days.
Delivery time is 2-5 days on average via usps priority mail.
</FONT>
<FONT SIZE="4">Part #: 30-4100
Availability: In Stock Ready To Ship
Retail Price: $349.41
<FONT COLOR="red">Phearable.net Sale Price: $245.99</FONT>
</FONT>
<FONT SIZE="5">To order visit our website by clicking here!
</FONT>
<FONT SIZE="4">Click here to visit phearable.net</FONT>
__________________________________________________ ___________
<FONT COLOR="blue"><FONT SIZE="4">AEM Tru Boost Gauge & Boost controller</FONT></FONT>
<FONT SIZE="2">
AEM's TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It's that simple, and IT WORKS!
AEM's TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 psig pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 psia boost sensor for high boost applications (sold separately).
AEM's boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won't corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
Features:
- No external interface required for programming!
- Complete system includes harness, boost hose, on-board 29 psig pressure sensor (external 75 psia optional), boost solenoid, gauge display and all necessary fittings
- Quick connect technology eases the installation process
- Two user selectable boost settings with peak boost memory
- Scramble boost setting allows user to momentarily change boost levels
- User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% overboost
- User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
- One (1) low-side output included for warning lights
</FONT>
<FONT SIZE="4">Part #: 30-4350
Retail Price: $345.45
<FONT COLOR="red">Phearable.net Price: $295.99</FONT>
</FONT>
</FONT>
Modified by phearable at 6:20 PM 10/16/2007
Old Jul 20, 2007 | 11:39 PM
mtber's Avatar
Default Re: AEM Uego Wideband 6 in 1 Gauge | AEM Tru-Boost Controller - In stock ready to ship! (phearable)
ttttttttt
Old Jul 21, 2007 | 03:19 PM
mtber's Avatar
ttttttttttttttttttt
Old Jul 23, 2007 | 04:58 PM
mtber's Avatar
tttttttttttt
Old Jul 30, 2007 | 10:21 PM
mtber's Avatar
ttttttttt
Old Jul 31, 2007 | 01:35 PM
mtber's Avatar
ttttttttttttt
Old Aug 3, 2007 | 02:57 PM
mtber's Avatar
ttttttttt
Old Aug 3, 2007 | 07:03 PM
mtber's Avatar
ttttt
Old Aug 4, 2007 | 09:09 AM
mtber's Avatar
tttttt
Old Aug 9, 2007 | 09:34 AM
mtber's Avatar
tttttttt
Old Aug 9, 2007 | 07:48 PM
mtber's Avatar
ttttttttttttt
Old Aug 10, 2007 | 09:53 PM
mtber's Avatar
tttttttttttt
Old Aug 11, 2007 | 04:06 PM
mtber's Avatar
tttt
Old Aug 13, 2007 | 04:27 AM
mtber's Avatar
ttttttttttt
Old Aug 13, 2007 | 01:27 PM
mtber's Avatar
tttttttttttttt
Old Aug 15, 2007 | 08:03 PM
mtber's Avatar
ttttttttt
Old Aug 17, 2007 | 12:10 AM
mtber's Avatar
ttttttttt
Old Aug 17, 2007 | 10:36 AM
mtber's Avatar
tttttttttttt
Old Aug 20, 2007 | 01:28 AM
mtber's Avatar
tttttttt
Old Aug 20, 2007 | 08:26 PM
mtber's Avatar
tttttttttttt
Old Aug 21, 2007 | 11:00 AM
mtber's Avatar
Old Aug 22, 2007 | 10:00 AM
mtber's Avatar
Old Aug 23, 2007 | 02:32 AM
mtber's Avatar
ttttttt
Old Aug 23, 2007 | 11:27 PM
mtber's Avatar
ttttttttttt
Old Aug 24, 2007 | 01:50 PM
mtber's Avatar
tttttttttttttttttttttt
