Rebuild necessary?
Old Jul 20, 2007 | 08:29 PM
xyk's Avatar
xyk
Default Rebuild necessary?
This is a crosspost from TECH because there's not that much traffic over there. It may or may not be on-topic but regardless, the guys in here are just as knowledgeable and can probably give me some help...
My motor has been running poopy.
My cousin damaged my o2 sensor about 3 months ago. It throws CEL code #43 (Fuel supply system) everytime I drive about 5-10 mins into driving. I had a mechanic buddy drive it and he said it was definitely the o2 without me mentioning anything about it. The engine will bog and sputter if not warmed up for at least 15 mins. The cars power is about 65-75% of what it used to be. Fuel consumption is ~20mpg. I have driven ~2000 miles since I first discovered the problem.
Ya, I know, I shouldn't be driving it. Money has been tight and I am getting a new o2 this Tuesday. The motor has 89K on it and was running very reliably before the pooped o2.
Possible any damage may have been done that I will now regret to the tune of a rebuild? What do I do from here? Run a compression test?
I appreciate your flames, but somebody got advice too? To pour gasoline on myself, its a B18c1.
Old Jul 20, 2007 | 08:37 PM
WhiteEKgsr's Avatar
Default Re: Rebuild necessary? (xyk)
as long as it runs fine after you replace to 02 you should be good to go, and it should run fine
bmoreb18c1
Aug 13, 2012 01:14 AM
gemini05
Jun 18, 2006 03:25 AM
boostinh22
Nov 29, 2005 11:15 AM
ITR 2K
Feb 2, 2002 11:25 AM
