How often is "Safe" Spraying?
After installing the Zex this weekend, I am scared every time I reach for that little red switch. Is this going to become addictive, am I going to loose, should I arm, am I running lean????
Ack.
How often do you guys consider spraying moderate/safe?? 1x/day, 1x/every 2 days, 2x/day... I'm running a 55hp dry Zex shot, and after installing it Thursday night, I have sprayed about 5 times. Not 15 sec sprays or anything, about 5 secs each (Enough to get off the line, or taking off from 3rd and shutting down in 4th).
How much/How quick do you guys go through a bottle, and what kind of setups do you use? How often do you spray, and how often is spraying on a stock (I/H/E) B16a safe?
jB
Ack.
jB
I have a ZEX kit and I have only used one bottle but I have used it alot. lets see
took friends for a ride about 6 times
5 1/4 mile passes and about 6 street races
my 10 lb bottle last alot longer than I thought it would
you should be fine to spray as much as you want as long as you dont run lean your ok...........dont you just love your ZEX kit?
I had a 50 shot dry NOS setup and went thru 1 bottle a week for 4 months straight without any problems at all. After 16 bottles, I sold it to come to the turbo dark side. $30 a week to fill a bottle got old quick.
cliff666
30
Nov 20, 2003 02:26 AM
sharkey65a
Jul 4, 2003 01:32 PM
What has eveyone run with Nitrous on there Integra's? Also what do you think ill run with a Zex Kit.
DK4200
Apr 7, 2003 09:28 PM
