How often is "Safe" Spraying?
Old Jun 9, 2002 | 09:24 PM
pelotudo's Avatar
Default How often is "Safe" Spraying?
After installing the Zex this weekend, I am scared every time I reach for that little red switch. Is this going to become addictive, am I going to loose, should I arm, am I running lean????
Ack.
How often do you guys consider spraying moderate/safe?? 1x/day, 1x/every 2 days, 2x/day... I'm running a 55hp dry Zex shot, and after installing it Thursday night, I have sprayed about 5 times. Not 15 sec sprays or anything, about 5 secs each (Enough to get off the line, or taking off from 3rd and shutting down in 4th).
How much/How quick do you guys go through a bottle, and what kind of setups do you use? How often do you spray, and how often is spraying on a stock (I/H/E) B16a safe?
jB
Old Jun 9, 2002 | 09:27 PM
-=TWITCH=-'s Avatar
Default Re: How often is "Safe" Spraying? (PeloTudo)
I have a ZEX kit and I have only used one bottle but I have used it alot. lets see
took friends for a ride about 6 times
5 1/4 mile passes and about 6 street races
my 10 lb bottle last alot longer than I thought it would
you should be fine to spray as much as you want as long as you dont run lean your ok...........dont you just love your ZEX kit?
Old Jun 9, 2002 | 10:28 PM
MugenSi00's Avatar
I had a 50 shot dry NOS setup and went thru 1 bottle a week for 4 months straight without any problems at all. After 16 bottles, I sold it to come to the turbo dark side. $30 a week to fill a bottle got old quick.
xfrankx
Feb 8, 2005 02:00 PM
cliff666
30
Nov 20, 2003 02:26 AM
sharkey65a
Jul 4, 2003 01:32 PM
redteg1
Dec 31, 2001 11:18 PM
