Oil problem
I replaced the head on my sohc ZC because the car was over heating but now that **** is burning a quart of oil a day so I have to put oil everyday It would burn oil before but not that much. I checked if there was oil in the spark plugs but nothing, there's no leaks in the head or any were else PLEASE HELP ME OUT...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">hone the block (if possible without having to overbore) and install new piston rings</TD></TR></TABLE>
Don't do that before doing a comp. test. Do a comp test, then put a teaspoon of oil in the cylinder, then do it again. If the numbers go up, it's your rings. If not, your rings are fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">where else would that much oil be coming from? valve seals wont leak like that</TD></TR></TABLE>
Yeah, you're most likely right, I was just suggesting spending 5 minutes to make sure it really was the rings before tearing the entire engine apart.
standbackimapro
25
Jul 9, 2007 11:34 AM
gregv
11
Dec 23, 2005 02:08 PM
