Vibration in the Steering Wheel
If I am driving around 40-60 or 100-120 I feel vibration - but not while braking
I check everything in front end area...but nothing I can shake with my hand..
but so far I replaced , all 4 tires, upper control arms and both drive axles (re manufactured)
so what would be the next.. any input will be appreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PSwagon »</TD></TR><TR><TD CLASS="quote">try getting your tires re-balanced.</TD></TR></TABLE> or wheel allignment
I switched front tiers to back to illuminate rim bent, but no go - front end still shaking.
now about the transmission half shaft - I don't know about this; how do I check this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord »</TD></TR><TR><TD CLASS="quote">well at 120 i would think you would feel some type of vibration.</TD></TR></TABLE>
yes; indeed I do feel vibration, plus my steering wheel is shaking back and forth like crazy, and thats what I am talking about, I show it to my mechanic too...but they have no idea yet...
I would have said the balance of the wheels or the axles but since you got new tires I assume they balanced them and you said you got new axles. I'd check still for a bent rim although you should have felt it move to the back if you switched them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dothacker »</TD></TR><TR><TD CLASS="quote">how are your bearings, when was the last time you checked them?</TD></TR></TABLE>
hmm, that could be it, yes I check my wheels holding by 12 and 3 o clock positions, but I couldn't feel any play at all, however some ppl say even if you don't feel play wheel bearings can be bad...
I would like to have some more in put before I spent my arm and leg....
I truly appreciate all you guys help -
Thanks again.
Thanks again.
Does your car have the Honda factory wheels on it? Some wheels are very hard to balance. I had aftermarket wheels on my Toyota that were almost imposible to balance. One time, out of about 10 tries they got it real close. Unfortunatly, I made the mistake of going for perfect, and ended up back at terrible.
yes; I have Honda factory wheels - tires are brand new Goodyear stock size. only thing I didn't do is replace ball joints, tie rods, wheel bearings - rotors and pads....(no vibration while braking so - no need new rotors and pads right)
I am taking her to shop coming Friday, will see what they going to find this time?
I am 6ft...tall quit strong big guy, I can't believe I couldn't shake anything under the car's front end...lol
edit
Oh I forgot to tell you guys, today car start to wobble (steering and front driver's side wheel) - now I am pretty sure something is loose, but don't know what.
edit
Ok; back from shop, now they tight my axle nut(spindle nut) to 181 Lbf-ft, said wheel bearings are fine - couldn't find any loosed parts.
Went to the Alignment shop, guy said everything right on the money - no need any adjustment.
Wheels are well balanced - but still wobbly steering - now he asked me to go to the tire shop and get them to change front 2 tires, because they may have some defects...
Tire shop guy told me to bring the car Monday - and will change them or upgrade all 4 tire to something better than "S" rated tires - but I will have to pay the difference -which I don't mind.
Thanks for all the help....let you know what happend.
Have a good Weekend.
