wat color is the ignition wire?
Old Jul 20, 2007 | 03:49 PM
slikz714's Avatar
Default wat color is the ignition wire?
like the title says..wat color is the ignition wire? im trying to put splice up my alarm wires back after the dealership had to cut them
its a 1998 civic
Old Jul 20, 2007 | 05:01 PM
JSPECSIR's Avatar
Default Re: wat color is the ignition wire? (slikz714)
hope this helps.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 1998 / Remote Start
[PRINT THIS PAGE]
12volts white (40A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Keysense blue/white to blue/red - ignition harness
Power Lock green/white - driver kick, blue plug
Notes: Also found in the green factory alarm plug located behind the radio.
Power Unlock green/orange - driver kick, blue plug
Use blue/yellow to unlock the driver door only.
Lock Motor white/red 5wi driver kick, door harness
Unlock Motor blue/red to yellow/red 5wi pwr door lock ctrl unit in driv door
Parking Lights+ red/black + driver kick, fuse box
Notes: Male blade terminal at fuse box. Also at the back of the dimmer switch.
Parking Lights- N/A
Hazards same as turn signal wires
Turn Signal(L) green/red + steering column
Turn Signal(R) green/yellow + steering column
Reverse Light green/black + driver kick, harness to rear
Door Trigger lt. green/red - factory alarm plug
Can also be found in a light green plug above the fuse box or bottom of driver kick, harness to rear.
Dome Supervision lt. green/black - driv A pillar or factory alarm plug
Trunk/Hatch Pin blue/black - driver kick, harness to rear
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm factory remote only
Factory Alarm Disarm factory remote only
Disarm No Unlock factory remote only
Tachometer blue ac test tachometer connector
Notes: Driver side fire wall under hood.
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake red/green - parking brake switch
Horn Trigger blue to gray - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Smart Starter Kill Relays: Not Available
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Old Jul 21, 2007 | 03:11 PM
hondadr.'s Avatar
Depends on what brand u got on
Kem=blue, green
GKI=blue purple
SDR=9blues
Old Jul 21, 2007 | 03:27 PM
JSPECSIR's Avatar
Default Re: (hondadr.)
om, what the hell are ^you^ talking about?
TwoFaced
Dec 16, 2010 05:34 PM
JLEK
Audio / Security / Video
May 22, 2007 09:04 AM
choppin_civic
Jun 10, 2006 10:50 PM
njandrewg
Mar 9, 2005 12:22 PM
yoshi234
Feb 12, 2003 08:29 AM
