bad gas mileage
Old Jul 20, 2007 | 03:43 PM
1.8L_allmotormilitia's Avatar
Default bad gas mileage
only mods:
-skunk2 intake manifold
-ITR throttle body
-AEM short ram intake
-dc 4-2-1 header
-chipped ecu (o2/knock sensor removed)
Why am i only getting 50 miles on less then half a tank keeping my rpms below 3500? My car would have better gas mileage with my exhaust/test pipe
I know most of you are going to say it's my ecu.
Old Jul 21, 2007 | 12:07 PM
any suggestions?
Old Jul 21, 2007 | 01:38 PM
DBAl's Avatar
Default Re: (1.8L_allmotormilitia)
Low tires?
Old Jul 21, 2007 | 02:13 PM
Default Re: (DBAl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBAl &raquo;</TD></TR><TR><TD CLASS="quote">Low tires?</TD></TR></TABLE>
hmm its retarded size tires 195/60/15 with about 33 psi in the front and 30 in the rear.
Old Jul 21, 2007 | 02:20 PM
numbnuts22715's Avatar
im gonna go ahead and bet that the chipped ecu is messing it up.
You really dont have enough mosd to even need it, due to the fact the o2 sensor is disabled it could be messing things up, but thats just my opinion.
Old Jul 21, 2007 | 02:31 PM
posHonda's Avatar
o god why are you running that tire size? if you just needed something cheap because of money issues than i completely understand lol i had to run 185/60/15s because i got them for $10 each and i needed them at the spot. yea it sucked horribly.
im going to say its your chipped ecu also. your supporting mods just arent enough to justify needing one yet.
Old Jul 21, 2007 | 02:33 PM
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">o god why are you running that tire size?</TD></TR></TABLE>
car came with it and tires are brand new im not going to trash them yet. if anything i run azenis always 205/50/15.
Old Jul 21, 2007 | 04:20 PM
aaronISthrowed's Avatar
Default Re: bad gas mileage (1.8L_allmotormilitia)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8L_allmotormilitia &raquo;</TD></TR><TR><TD CLASS="quote">
There you go.
Old Jul 21, 2007 | 07:02 PM
benjamin626's Avatar
Default Re: bad gas mileage (aaronISthrowed)
with that setup i'd think that you are running lean with all that airflow and not having an O2 sensor will mess with the ecu and make the injectors squirt more fuel??? my 2cents. i'm a noob, don't trust me yet.
Old Jul 21, 2007 | 10:34 PM
supracrx's Avatar
exactly what other said...what else are u using to monitor fuel? the o2 sensor is a BIG contributor. the o2 reads engine condition out of the exhaust..if it reads high oxygen it suspects lean mixture and therefore tell the ECU to throw more fuel to correct it...and vice versa for rich mixture. knock sensor can also effect timing, which could effect it also.
Old Jul 21, 2007 | 11:42 PM
wardseg6's Avatar
Default Re: (supracrx)
just put back on the damn o2 sensor and see what happens!
Old Aug 2, 2007 | 06:31 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
ur pressing the gas to much ! meketch chill on the gas pedal !
whiteboy-dc4
Engine Management and Tuning
Jan 9, 2009 12:19 AM
sickofitall1113
Nov 10, 2006 12:41 PM
happy_guy
Sep 20, 2005 12:58 PM
Komptech
Feb 18, 2005 11:25 AM
jamessh1
May 12, 2003 06:17 PM
