Car wont start, please help.
I have a 01 type r bone stock, put an ob1 ecu on it with a jun chip and car ran fine, only problem was that it was not revving past 7500 rpm. Was trying to figure out wat that could be. So i changed back to the original ecu not to drive but just to see if i had any check engine codes. Now the car wont start. Note the original ecu never started the car due to the fact that someone tried to steal it and messed up the immoblizer. All i get is a ticking sound and that is it, does not even turn over. Need help. I tried different comps nuttin, but they work fine on other cars.
Check the two top left fuses under the hood. First one should be a 10 amp fuse and the second one should be a 7.5 amp fuse.
K i l l a B e e.
11
Sep 1, 2008 01:08 AM
spyz34
Mar 20, 2005 12:49 PM
wadespade
Jul 27, 2004 05:27 AM
