Tach bouncing
Old Jul 20, 2007 | 02:13 PM
bkmc24's Avatar
Default Tach bouncing
My tach is bouncing when i accelarate and basically always. what can id o or replace to fix it.
Old Jul 20, 2007 | 02:29 PM
hatchling37's Avatar
Default Re: Tach bouncing (bkmc24)
That's when it's time to shift
Old Jul 20, 2007 | 02:35 PM
SiRek4
Guest
Posts: n/a
Default Re: Tach bouncing (hatchling37)
do you have msd?
Old Jul 20, 2007 | 02:44 PM
Braco11's Avatar
Default Re: Tach bouncing (SiRek4)
check your dizzy
Old Jul 20, 2007 | 10:38 PM
bkmc24's Avatar
Default Re: Tach bouncing (Braco11)
Dont have MSD. IM geting a Zc soon, should i just get a new cluster and say expletive it or what?
Old Jul 21, 2007 | 03:05 PM
hondadr.'s Avatar
you should try to open the dash and look if the gaudge has staining on the back if it does wipe it and try it again
Old Jul 22, 2007 | 08:41 AM
bkmc24's Avatar
Default Re: (hondadr.)
That doesnt make sense. So my motor just died, it runs but when i give it gas it missed and just is all hesitant. Any ideas? Also what is the dizzy? No one has ever answered that question for me lol
Old Jul 22, 2007 | 08:54 AM
Bejita's Avatar
Your ignitor in your dizzy is bad.
Old Jul 22, 2007 | 10:15 AM
97Ej6mike's Avatar
Do you mean to say your tach is malfunctioing (by bouncing) and your motor works fine, or is your motor doing what your tach is showing?
If the first statement is your case, its a wire/tach problem. Can be caused by a bad cluster (needle is busted) or a wiring problem somewhere.
Old Jul 22, 2007 | 10:23 AM
Syndacate's Avatar
Default Re: (bkmc24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 &raquo;</TD></TR><TR><TD CLASS="quote">That doesnt make sense. So my motor just died, it runs but when i give it gas it missed and just is all hesitant. Any ideas? Also what is the dizzy? No one has ever answered that question for me lol</TD></TR></TABLE>
Dizzy = Distributor
Old Jul 22, 2007 | 10:48 AM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (Syndacate)
Pop your hood and look at your Dizzy. Now see if there is any play on the blue wire. If so, push it in on both sides and see if that helps. It did for mine.
Old Jul 22, 2007 | 05:01 PM
bkmc24's Avatar
Default Re: (Bejita)
What do you mean ignitor? I literally just a whole new Coil, Igntion module, Cap Rotor and plugs and wires.
Old Jul 22, 2007 | 05:04 PM
bkmc24's Avatar
Default Re: (5_Lug_B)
And what blue wire? I see like 5 of them.
Old Jul 22, 2007 | 05:09 PM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 &raquo;</TD></TR><TR><TD CLASS="quote">And what blue wire? I see like 5 of them.</TD></TR></TABLE>
The solid blue (no stripes) is the signal from your dizzy to your tach on your cluster, check it to make sure it is properly connected.
Old Jul 22, 2007 | 05:12 PM
1992Si's Avatar
You'll need to replace your dizzy. Go to a auto parts store and order a rebuilt dizzy.
Don't bother trying to replace the ignitor it's $90.00. Been there done that.... Just get a rebuilt dizzy for $170.00. It comes with all new pieces.
Old Jul 22, 2007 | 05:26 PM
bkmc24's Avatar
Default Re: (1992Si)
I just pulled my CEl, its injectors, anyone ha this before? Should i run injector cleaner before i buy new ones?
Old Jul 23, 2007 | 06:16 AM
Syndacate's Avatar
Default Re: (97Ej6mike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike &raquo;</TD></TR><TR><TD CLASS="quote">
The solid blue (no stripes) is the signal from your dizzy to your tach on your cluster, check it to make sure it is properly connected.</TD></TR></TABLE>
Think it takes a break by the ECU first...but yeah, solid blue, tach signal.
Old Jul 23, 2007 | 06:19 AM
kuja396's Avatar
Mine does the same thing sometimes. The car runs perfectly. I have a little over 250k miles on my car though, so I assumed it was just a tired gauge cluster.
Old Jul 23, 2007 | 10:02 AM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bkmc24 &raquo;</TD></TR><TR><TD CLASS="quote">I just pulled my CEl, its injectors, anyone ha this before? Should i run injector cleaner before i buy new ones?</TD></TR></TABLE>
Worth a shot IMO, just make sure you run your tank down to a 1/4 tank or less before you add that stuff, works best that way.
Fatcobra
Apr 17, 2007 05:20 AM
frostee trooper
Feb 6, 2005 10:58 PM
