95m eagle crank, Rod, 85.5.. Spark Racing pistons, Supertech Valvetrain WHAT CAMS ?
Old Jul 20, 2007 | 12:10 PM
BlkSpoonEk9's Avatar
Default 95m eagle crank, Rod, 84.5.. Spark Racing pistons, Supertech Valvetrain WHAT CAMS ?
I have 95mm eagle stroker kit with spark racing pistons
the pistons are cast and keeping the sleeves stock but boring and honing. I also have a supertech valve train with high comp valves. C/R should be aronnd 12.0 - 12.5 i need a good set of cams for this setup? And also i gave Crane stg2 and Buddyclub spec 4 cams at my disposal would those be a good choice. and Also what Crank pulley? can i use stock if the whole rotating assembly is being balanced
Old Jul 20, 2007 | 12:26 PM
function83's Avatar
Default Re: 95m eagle crank, Rod, 84.5.. Spark Racing pistons, Supertech Valvetrain WHAT CAMS ? (BlkSpoonEk9
How are you using the spark racing pistons?
Which rods, stock or custom length?
The ones they have on their site is for 89mm or 87.2 mm stock stroke cranks.
I know the eagle 95mm crank uses ls rods with custom pistons with the wrist pins moved up further in the piston. So that the larger stroke fits in a deck heighth of
a stock block.
Old Jul 20, 2007 | 12:29 PM
Really? are you 100% on this?
Old Jul 20, 2007 | 12:31 PM
Hardt's Avatar
not going to work
Old Jul 20, 2007 | 12:40 PM
what will work what steps do i need to order custom pistons or does a company sell what i need off the shelf???????
Old Jul 20, 2007 | 01:37 PM
Hardt's Avatar
Well, the only real factors youve shared are the pistons you will be using, which Im assuming are 1.181 compression height and the fact that your using a 95mm crank. What rods are you using? Whats the center to center length? Have you measured the deck height of your block so you can get the exact figures for any custom parts you may need?
Old Jul 20, 2007 | 01:59 PM
B20b Block Bored and honed 84.5mm
Spark racing pistons
eagle rods CRS5394A3D
95mm eagle crank
Old Jul 20, 2007 | 02:02 PM
DonF's Avatar
You would need B16 rods with those pistons and crank. Not exactly what I would suggest if you are going above 7800 RPM.
Old Jul 20, 2007 | 02:08 PM
Hardt's Avatar
Don is correct, with your current set up youll be sticking out of the hole .099. Thats with a completely virgin/uncut block. Maybe even more if it has been decked. Using b16 rods will put you at .005 under, again, calculating that with a 8.346 deck.
Old Jul 20, 2007 | 02:10 PM
95mm eagle crank
Old Jul 20, 2007 | 02:11 PM
i think imma just stick with a stock ls or b20 crank should still make power that wayi just really wanted that stroke
Old Jul 20, 2007 | 02:16 PM
Old Jul 20, 2007 | 02:38 PM
Hardt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlkSpoonEk9 &raquo;</TD></TR><TR><TD CLASS="quote">I have 95mm eagle stroker kit with spark racing pistons</TD></TR></TABLE>
Too many fictional set ups being posted in this forum.
Old Jul 20, 2007 | 03:03 PM
DonF's Avatar
Yannx13
Oct 16, 2012 04:56 PM
prodragEG
Jun 8, 2008 08:54 PM
fmfkid250
11
Nov 29, 2006 05:58 AM
Baggy Spandex
Nov 1, 2005 12:02 PM
ahki
Jun 17, 2003 02:54 AM
