open end lugs for Bogarts? where?
Hey guys...I have a set of Bogart Drag-on flys. I bought them with lugs and washers. Here's the deal, I just bought some DSS stage 3 axles and they came with extended studs. THe Lugnuts that came with the rims are closed and I need some open end lug nuts. Where can I find these? They have to have a flat surface where it is sitting on the rim...
Viren, Mike, anybody else that runs bogarts with extended studs...where did you get them?
TIA
TIA
I carry them and they are from BOGART wheels. But there are some places that people have told me that carries the same lugs.
Wil
Wil
my friend has extended studs on his car and hasnt bought the right lugnuts for them, so in the meantime he took the stock lugnuts and sawed the ends off of them. cheap way out but i just thought i share.
I know Skunk2 makes some that are open end and Koyougen or whatever its spelled, I'm running the skunk2 extended studs with lenso's and the Koyougen lug nuts and it seems to work pirtty good...
Adi
Yeah, when I bought my Bogarts...I actually went to the factory my self. Mrs. Bogart actually hooked me up with some free of charge cause she is soo nice. I guess in answer is from Bogart. KG Precision Engineering is also a dealer for them and he has them in stock........Mike
PS: you can not run stock type lug nuts with these wheels so sawing off the ends will not work as well as the koyougen nuts.
[Modified by ninesecrx, 9:23 AM 6/10/2002]
