tranny problem please help!
Old Jul 20, 2007 | 08:46 AM
sweetredtegi1's Avatar
Default tranny problem please help!
I have a 94 integra ls 5 speed. The problem i have is that my tranny is leaking fluid from the passanger side axle seal that ive already replaced. The real problem i have is i can move the axle around while its in the tranny. What could this be. Thanks for any help.
Old Jul 20, 2007 | 08:52 AM
hatchling37's Avatar
Default Re: tranny problem please help! (sweetredtegi1)
You can move it after it's been installed? Are you 100% sure you have the correct axle? If not, that could explain your "faulty" axle seal...
Old Jul 20, 2007 | 11:48 AM
Bakeoff's Avatar
I'm guessing you can make it wobble...
That's a sure fire sign of a diff that's ready to go.
When it's wobbling, it stretches the diameter of the seal opening and lets it leak.
Do yourself a favor and throw in an OBX LSD before it goes and blows the whole thing up. The labor is easy enough. Just need the diff, some oil, and a tube of rtv...
Old Aug 10, 2007 | 11:19 AM
aladdin's Avatar
I'm having exactly the same problem. Same year and model integra. It's been for six months now. I bought a new axel and tranny oil seal. Do you think it can be fixed without having to buy an LSD?
Old Aug 10, 2007 | 04:26 PM
slowcivic2k's Avatar
Default Re: (aladdin)
There should be a little bit of play in the axle, but if you really suspect you screwed up the diff, pull the axle out and pry a screwdriver in there and see if the bearings are toasted. Make sure you replace the seal with an OEM Honda one, the aftermarket autozone specials are a loose fit, as this problem plagued me for a very long time.
Old Aug 11, 2007 | 02:03 PM
aladdin's Avatar
Default Re: (slowcivic2k)
Great! Today I started to hear clunking noise when I take sharp turn to the right. It sounds like the noise is coming from the inboard CV joint where the leak is. That might explain the condition of the diff!
nicknack25
Nov 5, 2010 08:06 PM
ALLINWONDER
Jan 17, 2006 06:00 AM
h22zexhatch
Jun 22, 2005 10:29 PM
1fastgsrturbo
Apr 3, 2004 06:26 PM
preluder
Jul 15, 2003 08:23 PM
