Clutch / Tani problem?
Old Jul 20, 2007 | 08:36 AM
phoenixfire425's Avatar
Default Clutch / Tani problem?
Ok. I am really confused with this issue.
I am getting a whine sound when I start to engage the clutch from a stopped position. But not all the time. But it seems to be more when its warm out.
Also no the even bigger problem is. When I am in acceleration the car jumps. Almost like the clutch is not engaging. Especially when I hit vtec.
And now this morning I was driving and I was at about 40 mph in 4th gear and it started to jump again and you can her the motor make a different sound when it does to the jumping. But I do have a 3” exhaust so you can hear everything. Haha.
My thoughts were the throw-out bearing (release bearing) and then I was thinking it might be the pressure plate is losing the grip
And just for the info. The clutch is not slipping when going into gears. So the clutch face should be good. What should I check or do?
I was thinking about just getting a new clutch, pressure plate, throw-out bearing, and lightweight flywheel. But that was before this problem. But now its really and option.
Thanks for your Help
~Corey
Old Jul 20, 2007 | 09:02 AM
chitownrida's Avatar
are the revs jumping up? it may be your clutch is dead
Old Jul 20, 2007 | 09:29 AM
Default Re: (chitownrida)
well when the car jumps the RPMS jump too. also somehting i noticed that i did not mention would be that. when i am sitting stil land i dont put it in gear and i let off the clutch you can hear a different sound. almost like well i cant really desribe it. but its def there.
Old Jul 20, 2007 | 09:36 AM
usually the throwout bearing will make noise when u step on the clutch to engage a gear, but the revs jumping up while driving definately says to me that the clutch is slipping
Old Jul 30, 2007 | 11:33 AM
ok well i ordered this kit from Prostreetonline.com
http://www.prostreetonline.com/pnsku/psmxa31.asp
Tell me what you think.. and well as i am waiting for it.. i guess i will just driver the car. lol. its been getting worse. it it starting to drag really bad.. Put it this way.. i am staying out of VTEC.. because there is no point. it slips to much.
Old Aug 7, 2007 | 09:44 AM
Default Re: (phoenixfire425)
well i got the parts and i will be installing them this weekend. wish me luck. does anyone have any pointers?
Old Aug 7, 2007 | 04:47 PM
snobordboy's Avatar
Moderator
search for the how-to someone did like 4 years ago its great, and get a Helms!! Oh and air tools are very helpfull, especially for the axle bolts! Thats about it for me.
Zteve
Nov 18, 2009 08:46 AM
JDM3STAGEVTEC
Dec 19, 2008 07:43 PM
vlc92189
Aug 30, 2006 11:10 AM
ludelvr
Sep 28, 2003 11:02 AM
integRated109
Jul 4, 2002 01:53 PM
