1992 CIVIC VX HATCH W/ B16A2 SWAP!!!! ALSO A TRUCK LOAD OF OTHER PARTS WITH IT
1992 CIVIC VX HATCH W/ B16A2 SWAP. The 5 wire to 4 wire o2 wiring is done. The oxygen sensor extension is in and the car runs great. The only known issue is the idle motor needs to b replaced because the idle surges at stop signs. The previous owner had replaced the crank and lower end bearing due to a spun crank pulley. They only have maybe 2000 miles on them. The engine only gets mobile 1 full synthetic oil since I have had it. The car has no rust and was from Georgia. There is some denting of the right rear quarter panel and some bondo on the left rear near the rear window. I do not know the history on that though. When I got it the radiator support was trash so I replaced it with another one from a parts car I had. The front hood and fenders are replacements as well. The headlamps are a nice set of projector lamps with the relays and all installed. All the body needs is some tlc and paint. The interior is not horrible but needs some work too. I replaced the front seats and got a back seat as I received the car without one. Needs carpet and trunk carpet at least. Under the hood has the b16a2 ( valve cover cut for cam gears), a blue Aem fuel rail, DSM 450cc injectors, resistors wired in, and the fuel tank has a walbro 255lph pump. I was setting this up for turbo application. Included with the car is a front mount intercooler, charge pipes (silver coated), a B series t3 turbo manifold, 1g dsm bov, tuner toys oil line kit (brand new in box and only opened to look at and make ready to install), a Garrett t3 turbo (like new only 700 miles on it), down pipe for the turbo, and a socketed p28 with 1 chip. You will need to have it burned with a map. I can provide the base map I got from phareable.net. The vehicle runs and drives currently with my ostrich installed. I don’t have a chip burner so if you don’t have a chip burned it will not be drivable. The other items with the vehicle would be a set of 99 si wheels, 3 are decent but not perfect and one is bent. They were like this when I got them and I have never put them on the car. I am also including every other Honda partS I have as I am getting out of the Honda game.
1 b18a1 block, head, crank, pistons, and rods, block and rod caps may be missing. (They might be gone or might be in the mess of stuff I have…
2 d16z6 heads (one almost assembled and the other was the parts donor)
oil pumps, oil pans, turbo housings and parts of misc turbos, some braided lines, one engine stand with the b18 on it., a second b18 head (from a b18b and it has one bad valve), b18 valve cover, d16 valve cover, air filter box parts, a d16z6 wiring harness (missing one plug and needs some repair soldering), 2 eg halo projector headlights ( one is good the other might be repairable (the back of the housing is cracked), 2 or 3 intake manifolds( I think 2 b18 and I d16), 2 dc2 door panels with handles and rods, a few misc engine and trans mounts, and im sure there is a bunch im forgetting.
<U>I will update the list and add pictures this weekend either Saturday or Sunday.
Price is $3750.00 O.B.O LOCATED IN SHEBOYGAN WI!!!!!
I DO NOT WANT TO PART IT OUT, SERIOUS INQUIRIES ONLY, AND LOWBALLERS KEEP LOOKING ELSEWHERE!!!!!!!!!!!!!!!!!! </U>
Modified by Tink2150 at 2:05 PM 7/20/2007
Only a couple items are need to finish boosting the hatch. All you will need is a wastegate and guages really. I will inlcude my moates ostrich and a tial 38mm wastegate if i get a decent price for everything. then all you would need is guages and some man hours to install it all. once its done you would have one hell of a solid boosted civic hatch...
Modified by Tink2150 at 2:07 PM 7/20/2007
there is a couple interior ones there also. i can take more of the outside tomorrow if you like but i promise that it doesnt look any different on the othr side...
the si's ride fine when i had them on my car it didnt shutter a whole lot, i knew they were out of balance a little but never got around to adjusting them. a simple balence should fix the bent one
Make me a honest and reasonable offer man. ill let them go for a decent price but im not going to give them away. Although since they came from you ill give you a little bit of a better deal...
