Support to themuffinman's cluster removal FAQ
Old Jul 20, 2007 | 05:47 AM
awdgsx96's Avatar
Default Support to themuffinman's cluster removal FAQ
*Before I start this thread let it be known that this is not my original work and figuring out! Credit belongs to themuffinman. I have talked to him and touringaccord, both giving me the OK to add pictures to themuffinman's thread!
Originally Posted by TheMuffinMan
It's a bitch to get to the cluster.
I'll make a list of what needs to be removed:
1) Inside arm rest, open the small panel at the bottom and remove those two screws
2) Pull up on cup holder (should pop out) there is one screw at an ANGLE at the front of the opening, ignore the two ones in the middle, remove that one angled screw
3) Pull up the ebrake if it's not already up and the entire armrest/cupholder piece should slide back and up (move it around the ebrake)
4) Two screws are in front of you now near the ebrake and behind the shifter on the black piece, remove those
5) Pull out the ash tray (straight out) and remove the screw above the OBD II connector
6) Pull out the Coin Holder, remove the screw behind that and pull off the steering column cover (about 8 clips)
7) The black center console should be loose now, kinda lift it up and out - there's two clips holding it near the radio
8) Unclip the lighter , clock, hazards, and fog connectors at the top and put the piece aside
9) Remove the two screws at the base of the radio (near the OBDII connector) and pull the radio out - unplug the main harness and the antenna
10) It should look pretty empty at this point, remove the two screws on the left side of the tan part of the center console (one up by AC controls, one below near bottom of steering column)
11) Kinda weird part, Open the glove box, there's two screws on the center console in similar areas, I was able to fanangle my way in there to remove them, take out both of these.
I wasn't able to get to them with the glove box in, so I just removed it. Just two gold screws on the bottom
12) Remove the two upper screws on the center console (silver and hex head)
13) The center console should now be free to be pulled out (you MAY need to remove your glove box - two screws on bottom + clipped on arm on the right side)
14) Put your hand on the back of the dash and pop out the Dimmer, Cruise/Sunroof, and defrost switches - behind the Cruise/Sunroof is a screw - remove that, behind the defrost is a screw - remove that as well
15) Look up under the Heating / AC controls where the clock/hazards used to be, you should see two small screws - remove those
16) Lower the steering wheel all the way and remove the two screws recessed where the cluster is
17) Congrats (haha) you can now pop out the black trim that holds everything in there, if you want you can just swing it carefully into your passenger footwell (what I do) or unclip/screw the heating/ac cable and pull it out
18) Now, you should see your naked dash, 4 gold screws hold in the cluster (2 on each side), remove these
19) CAREFULLY pull the cluster foward, there's three harnesses that attach to it, no way to describe what I did, but manuever it around to unclip those and pull it out, be careful as the cluster plastic can break easily
20) To take apart the cluster, remove the light bulb that connects to the top of it (there's two wires so just follow them) now there's two clips on the bottom and three on the top, carefully press all those in and the clear covering should slide off.
21) Removal of gauges and what not - Pull up on the flat covering that has the labels on it (it probably is already loose) this should expose everything else.
- Turn the cluster around this is what everything is:
1) Three screws hold in the Temp Gauge and Fuel Gauge
2) Four screws hold in the Speedo and the Tach
There are NO wires going to these pieces, I believe the power is transferred through the screws, so don't lose any and don't damage anything.
I may try to post pics up later since that's a pretty detailed explaination. Accord FAQ worthy haha
*Again, this is only my pictures to support another member's thread!*
Before driving to test speedo, make sure all harnesses are plugged back in. If you don't plug hazards you have no blinker, and if you do not put in the dimmer harness and cruise control harness, you have no speedo.
Modified by awdgsx96 at 8:36 AM 7/27/2007
Old Jul 20, 2007 | 05:53 AM
TheMuffinMan's Avatar
He knows where you live!
Excellent job
Glad I could help you get everything working again.
I may do some other tutorials too, how to remove interior parts is a possibility since I've stripped down my interior about 90%.
But awesome post, if anyone has any questions feel free to post up and either awdgsx96 can help you out or I can.
Old Jul 20, 2007 | 06:08 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Support to themuffinman's cluster removal FAQ
Nice job to the both of you
TheMuffinMan, if you do make some more tutorials, let me know and I'll add them to the FAQ
Old Jul 20, 2007 | 06:30 AM
Definitely will Touring, I may do a few more
Maybe door panels?
Maybe door actuator replacement (locks)
Might do full interior removal
Who knows!?
Old Jul 20, 2007 | 06:47 AM
H-T Order of Merit
Default Re: (TheMuffinMan)
sounds good
Old Jul 20, 2007 | 07:03 AM
awdgsx96's Avatar
What about window regulators?
I'm gonna try tackling that one next week.
And the trunk lock assembly. When I bought my car it didn't have one. I'm gonna buy one from tasauto soon and do that all mammajamma
Old Jul 20, 2007 | 07:21 AM
H-T Order of Merit
Default Re: (awdgsx96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">And the trunk lock assembly. When I bought my car it didn't have one. I'm gonna buy one from tasauto soon and do that all mammajamma</TD></TR></TABLE>
the part thats attached to the car or to the trunk lid?
When I sold the trunk lid from my 95 EX my girls brother and I swapped the keyed lock assembly on the lid for the guy pretty quick. It was straight forward and simple from what I remember, which isn't much that was probably 3 years ago.
Old Jul 20, 2007 | 07:33 AM
awdgsx96's Avatar
Default Re: (TouringAccord)
On the trunk lid. That's good to know then. Is it basically just mounting it on there and calling it a day?
Old Jul 20, 2007 | 07:41 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awdgsx96 &raquo;</TD></TR><TR><TD CLASS="quote">Is it basically just mounting it on there and calling it a day?</TD></TR></TABLE>
pretty much. I can't think of anything special we had to do. We unbolted the old one, maybe removed a couple clips of some sorta and installed in reverse order. I don't remember the exact steps because it was a while ago, but I know it's not hard. Just go to a junk yard and as you remove the part pay attention to the parts and whats holding it in, you shouldn't have a problem.
Old Jul 20, 2007 | 09:57 AM
awdgsx96's Avatar
Thank you sir
Old Jul 20, 2007 | 10:07 AM
H-T Order of Merit
yep, no problem
Old Jul 20, 2007 | 10:34 AM
scrooge's Avatar
whoa all that to take out the cluster? dam
Old Jul 20, 2007 | 10:52 AM
hondatuningboi96's Avatar
Default Re: (scrooge)
i know.
Old Jul 20, 2007 | 06:52 PM
Supposedly from tech8, the Haynes manual doesn't suggest taking out the lower dash cover, glovebox, and console - I still think the screws below the heating/ac controls would be difficult to reach
Old Jul 20, 2007 | 07:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I like to respectfully thank TheMuffinMan for his time and effort on creating this DIY for everyone.
The Helms manual doesn't list as procedures in taking out the lower dash cover, center console (upper part), or the glovebox to remove the gauge cluster. Essentially, the steps # 6, 10, 11, and 12 in the pictures above are not listed. I have replaced an instrument cluster, without removing these.
Here are the 2 essential screw areas and philips screws that need to be removed once the black bezel with the hazard switch, clock, etc. is removed from the center console. These pictures are from LEDautomotive.com. (The links originally posted by The-Kid on this forum.)
LEDautomotive.com links:
http://ledautomotive.com/HowTo...o.asp
Old Jul 20, 2007 | 09:06 PM
IHBH's Avatar
Default Re: Support to themuffinman's cluster removal FAQ (awdgsx96)
dang
Old Jul 20, 2007 | 09:45 PM
JDM_Acccord's Avatar
why was the center console removed? ive taken my cluster out without taking out my radio and the cover underneath the steering wheel.. i took my cluster out in a good 10 minutes.. why was all that necessary?
Old Jul 21, 2007 | 08:26 AM
awdgsx96's Avatar
Default Re: Support to themuffinman's cluster removal FAQ (JDM_Acccord)
Just how I saw works, and did it.
Old Jul 21, 2007 | 08:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Acccord &raquo;</TD></TR><TR><TD CLASS="quote">why was the center console removed? ive taken my cluster out without taking out my radio and the cover underneath the steering wheel.. i took my cluster out in a good 10 minutes.. why was all that necessary?</TD></TR></TABLE>
You HAVE TO take out at least the radio, you're missing quite a few screws otherwise
Old Jul 22, 2007 | 05:38 PM
awdgsx96's Avatar
Default Re: Support to themuffinman's cluster removal FAQ (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">Nice job to the both of you
TheMuffinMan, if you do make some more tutorials, let me know and I'll add them to the FAQ </TD></TR></TABLE>
I might have something for you. I got a slide hammer + the weldy gun thing that welds sticks to the panel to remove dents. I also picked up some hammers and dollies. A friend of mine works at an auto shop and let me borrow them. I'm gonna do pictures of progress, and the before and after.
Old Jul 22, 2007 | 06:10 PM
H-T Order of Merit
sounds good
Old Jul 22, 2007 | 06:42 PM
weezo182's Avatar
Old Jul 24, 2007 | 10:11 AM
jb.'s Avatar
jb.
Default Re: Support to themuffinman's cluster removal FAQ (weezo182)
I might have to do this since my speedometer just started acting weird like not starting until about 15-20mph and ticking left and right a little bit when going. Any ideas for my 95 ex
Old Jul 24, 2007 | 10:42 AM
Should apply to yours as mine and awd's
Try replacing just the back circuitry from a working speedometer. You will probably be fine after that.
As long as your cruise control works, it's most likely not your VSS (which should also trigger a CEL)
Old Jul 25, 2007 | 12:32 PM
jb.'s Avatar
jb.
would this also affect the odometer not increasing miles sometimes?
