suspension differences from non ITR
hey guys im not getting any good info from ANYONE so i figured id go to those who know more about the DC2 type r than others.
i want tokico dspecs
they only make them for DC2-R
i have an EJ1
alot of the DC2's suspension will transfer over to the EJ, my question is what is different btween DC2-R and regular old DC2 (or for that matter the EJ1) suspension components that will need to be swapped to make the transition?
trailing arms? LCA's? or is it a difference in the frame, making this a simply unfeasible project???
i have an EJ1
the only ITR specific part you'll need to run that suspension are the rear lower control arm's. Everything else is pretty much the same. I see ITR LCA's go for around $50 all the time in the for sale forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bacardiboi »</TD></TR><TR><TD CLASS="quote">and do i need ITR rate springs?? probly so huh</TD></TR></TABLE>
What?
An ITR suspension in itself, when refering to the shocks/springs is not that much different from your EJ. The front shocks/springs will fit with no problem.
For the rear, you will have to use ITR lower control arms.
I recently installed my old ITR suspension on an EJ and thats all that I had to do.
What?
This question was previously answered in your other post.
https://honda-tech.com/zerothread?id=2047406
bacardiboi
Jul 23, 2007 09:59 PM
