do civics and del sol's have the same front suspension parts????
i need to replace my lower control arm, hub assembly and the peice that bolts from the hub to the upper control arm. i have skunk2 upper control arms which is why im not going to replace them. reason im doing this is because i cant get a good wheel alignment because on either the passenger or drivers side something is really messed up so the only way to corrent for that is to have them both set at a 2* camber..
so, im going to head out to the junkyard on saturday and pick up the whole front suspension parts (minus struts) to hopefully straighten everything thing out. i need to know if integras and civics will have the exact parts im looking for (lower control arm, hub assembly and the peice that bolts from the hub to the upper control arm) thanks
Yes, the suspension components are the same. If you can find Integra parts, that would be even better since the brakes are larger and LCAs offer sway bar compatibility.
i have a 94 del sol with a factory b16. i think my car already has sway bars does it not. i honestly have not looked.
so will parts from a 92-2000 integra work. or is it just 94+? will i need to get the brake calipers as well if i get the larger brake rotors in the integra?
If you car is indeed a Del Sol VTEC (with a B16A3 stock), you have the same type of brakes as an Integra. So you will need parts from a 94-01 Integra.
xboxhaxorz
Sep 11, 2016 09:00 PM
Swansen
10
Jan 28, 2009 06:32 PM
