Help Installing lowering springs
Old Jul 19, 2007 | 11:06 PM
Toe_Knee's Avatar
Default Help Installing lowering springs
I've never done this before but I've looked online about it. So I just take off the wheels and switch out the stocks with the lowering springs right?
Old Jul 19, 2007 | 11:13 PM
dtec's Avatar
Default Re: Help Installing lowering springs (Toe_Knee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Toe_Knee &raquo;</TD></TR><TR><TD CLASS="quote">I've never done this before but I've looked online about it. So I just take off the wheels and switch out the stocks with the lowering springs right?</TD></TR></TABLE>
Basically, yeah. You will need a spring compressor or a clamp when taking off and putting on the springs.
Old Jul 20, 2007 | 08:57 AM
InvaderTrax's Avatar
May not be true of the new springs. I remember mine were the tiniest bit taller than the shock rod could reach, so I just put my weight on them and had someone run the nut down
Old Jul 20, 2007 | 09:01 AM
chitownrida's Avatar
make sure u get the spring compressor, the stock spring is gonna fly off if you dont compress it
u can rent them pretty cheap at autozone or advance auto
Old Jul 20, 2007 | 09:23 AM
Toe_Knee's Avatar
Default Re: (chitownrida)
Ok thanks guy. Do you remember if the longer spring goes in front or the back? I don't think they're labled...
Old Jul 20, 2007 | 04:36 PM
What springs are they? Any quality spring will be labeled
Old Jul 20, 2007 | 05:04 PM
Toe_Knee's Avatar
Default Re: (InvaderTrax)
Nevermind they actually were labled. I thought it was a part number or something. R/F in front of a bunch of numbers heh. Thank you!
shermanyang
Honda CR-V & Element
15
Mar 20, 2013 11:10 AM
EK4nut
Suspension & Brakes
Jun 13, 2007 02:51 PM
janz3n
Mar 23, 2007 04:27 PM
frostwhite_92
Suspension & Brakes
12
Mar 1, 2006 09:40 AM
vincepru
Suspension & Brakes
12
Oct 14, 2005 10:48 AM
