what will work with PRO-SERIES
other than skunk what other valvesprings will work?
also have a question i been thinking about buyin some valves, do i really need valves why yes or no please, the reason im thinking i need valves is cause when i picked up my pro2's the guy made it seem like i have to buy them or my valves will float at high rpm true? or was he just tryin to make a sell
Modified by DSRacing at 10:29 AM 7/20/2007
I ran into this issue... I ahve a set of pro1's that I bought after I bought a complete supertech valvetrain. Well, when having my machinist cut in the valves, I had him measure the retainer to valve seal height... yeah, with the supertech stuff, the pro 1 intake cam would supposedly cause the retainer to hit the valve seal
The skunk2 retainers made the clearance better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSRacing »</TD></TR><TR><TD CLASS="quote">other than skunk what other valvesprings will work?
Portflow as well.
Portflow as well.
thanx, i have the old skool skunk valve train but i guess that wont hold up for pro-series so i was told all i need to buy is the springs so i wanted to see what options i had. what about valves should i pick some up
stock gsr valves, head is at the machine shop need to drop off the parts including a valve job(first one) and never seen the valves out side the head before so i cant say, i like stock gsr there tough little suckers BUT like i said when i picked up my cams he said i should get valves so that they dont float at high rpm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe »</TD></TR><TR><TD CLASS="quote">
Portflow as well.</TD></TR></TABLE>
you know what come to think of it my brother had stock valves just a good valve job and had pro2's in it.
todd you tuned his 16:1 ls/vtec the black crx jake he shaves his head well anyways he used stock valves UNTIL he went pro3's and bent like all the valves no i just need to worry that i picked up pro2's not pro3's haha
Modified by DSRacing at 1:01 AM 7/21/2007
you know what come to think of it my brother had stock valves just a good valve job and had pro2's in it, todd you tuned his 16:1 ls/vtec the black crx jake he shaves his head well anyways he used stock valves UNTIL he went pro3's and bent like all the valves no i just need to worry that i picked up pro2's not pro3's haha</TD></TR></TABLE>
That is one LONG sentence.
The usage of stock valves is not what bent your brothers valves when using Pro3's.
sorry the thing i dont like about valves is that i always hear when you over rev them be ready for bent valves.(not that i over-rev I DONT)
my reason for wantin valves is that i was told its safer with these cams.
anyone ever try "BLUEPRINT" valve train getting good deal and was told i can use these
