Inspection Help
Ok so when i bought my car the speedo was bad it would stay at zero at all times even when im doing like 80mph... it was the cluster itself because i had checked everything it was the original cluster and read 210k miles... now i swapped in a new one and everything works fine but it reads 145k and i have to inspect my car... i heard that i can get into serious trouble at the dmv for swapping the cluster to a lower mileage is this tru its in NJ what should i do my inspection is in 2 days?
not sure what year civic you have, but i believe you can swap out just the odometer. not sure, but here is alink to give you a idea:
http://www.thehondapartsstore....ch=no
i have a 93 coupe but damn i see everybody swapping out clusters wtf so when i swap mine i get busted when i go to inspection??? damn i got the worst luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">i have a 93 coupe but damn i see everybody swapping out clusters wtf so when i swap mine i get busted when i go to inspection??? damn i got the worst luck</TD></TR></TABLE>
The Honda dealership should be able to roll it back for you.
As long as you show proper documentation it should be fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green »</TD></TR><TR><TD CLASS="quote">bump need help cuz i obviously cant drive my car until i get it inspected </TD></TR></TABLE>
I drove my car for 3 weeks when my inspection expired and it wouldn't pass because of electrical problems - cops really don't care unless they're doing a road check (towards the end of the month) - and even then, they usually just check colors.
Honda dealership should be able to match the #'s.
not roll it back i mean roll it forward cuz the motor has 210k and the new cluster reads 145k... and i was thinking of going to the dmv and trying to get away with it... because if the car has not been inpected in the last couple years theres a slim chance that their last inspection was before 145k miles
thisboyjulio
Sep 5, 2007 05:42 PM
