5th gear problems
Old Jul 19, 2007 | 05:10 PM
honda_conversion's Avatar
Default 5th gear problems
i swaped my d15 to b16 n i changed the shift linkage. y is my 5th gear pop out
Old Jul 19, 2007 | 05:13 PM
philosofy1's Avatar
Default Re: 5th gear problems (honda_conversion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_conversion &raquo;</TD></TR><TR><TD CLASS="quote">i swaped my d15 to b16 n i changed the shift linkage. y is my 5th gear pop out</TD></TR></TABLE>
maybe because you have a bad tranny? changing the linkage has nothing to due with the gears popping out.
Old Jul 19, 2007 | 05:14 PM
93baggedcivic's Avatar
trans could be on its way out
Old Jul 19, 2007 | 05:15 PM
JDM_SOHC's Avatar
Default Re: 5th gear problems (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
maybe because you have a bad tranny? changing the linkage has nothing to due with the gears popping out.</TD></TR></TABLE>
not 100% true... thats assuming he has the correct linkage...
Old Jul 19, 2007 | 05:28 PM
Default Re: 5th gear problems (JDM_SOHC)
it wouldnt pop out if it was low on trans fluid would it .
where could i find a tranny or a performance tranny
Old Jul 19, 2007 | 05:30 PM
Old Jul 19, 2007 | 05:33 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_conversion &raquo;</TD></TR><TR><TD CLASS="quote">it wouldnt pop out if it was low on trans fluid would it .
where could i find a tranny or a performance tranny</TD></TR></TABLE>
IMO, b-series trannies are hard to find, atleast for me. i would check
ebay
HT classifieds
http://www.gearspeedinc.com/home.htm
as for a performance tranny, there is none that i am aware of, but there is performance gears and final drives. you can always pick them up and rebuild the tranny.
Old Jul 20, 2007 | 02:55 PM
JDM_SOHC's Avatar
Default Re: (honda_conversion)
where could i find a tranny or a performance tranny </TD></TR></TABLE>
hmmmmm.. well besides honda not making any performance trannys, that just sounds expensive... what do u honestly need a performance tranny for..?? rebuild the one you own now, or pay someone to rebuild it, an that will work just fine... unless ur planning on like over 500hp a stock tranny "working perfectly" will hold up just fine... "i've only seen about 8000 hondas with stock trannys pullin out some sick *** numbers" haha...
whitelightning
Aug 7, 2005 05:55 PM
works909
Apr 9, 2005 09:03 PM
951dc5
Jan 22, 2005 05:38 PM
Burlyirishdude
Nov 23, 2004 09:34 AM
Skinnypunk
May 30, 2004 10:41 AM
