5th gear problems
Re: 5th gear problems (honda_conversion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_conversion »</TD></TR><TR><TD CLASS="quote">i swaped my d15 to b16 n i changed the shift linkage. y is my 5th gear pop out</TD></TR></TABLE>
maybe because you have a bad tranny? changing the linkage has nothing to due with the gears popping out.
1 Post
Re: 5th gear problems (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
maybe because you have a bad tranny? changing the linkage has nothing to due with the gears popping out.</TD></TR></TABLE>
not 100% true... thats assuming he has the correct linkage...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_conversion »</TD></TR><TR><TD CLASS="quote">it wouldnt pop out if it was low on trans fluid would it .
where could i find a tranny or a performance tranny</TD></TR></TABLE>
IMO, b-series trannies are hard to find, atleast for me. i would check
ebay
HT classifieds
http://www.gearspeedinc.com/home.htm
as for a performance tranny, there is none that i am aware of, but there is performance gears and final drives. you can always pick them up and rebuild the tranny.
ebay
HT classifieds
1 Post
Re: (honda_conversion)
where could i find a tranny or a performance tranny </TD></TR></TABLE>
hmmmmm.. well besides honda not making any performance trannys, that just sounds expensive... what do u honestly need a performance tranny for..?? rebuild the one you own now, or pay someone to rebuild it, an that will work just fine... unless ur planning on like over 500hp a stock tranny "working perfectly" will hold up just fine... "i've only seen about 8000 hondas with stock trannys pullin out some sick *** numbers" haha...
