oil in spark plug hole?
Old Jul 19, 2007 | 04:19 PM
usdmEHboy's Avatar
Default oil in spark plug hole?
My friend has a 91 integra with b16. We went to check out the spark plugs and cylinder 2 and 4 is soaked in oil..i'm talking like a pool of oil like 3 inches down. We couldn't even see the spark plug! I have no idea what the problem is..could it be a seal or something? thanks in advance
Old Jul 19, 2007 | 04:27 PM
TEGGSRB18C1's Avatar
Default Re: oil in spark plug hole? (usdmEHboy)
On the bottom of the valve cover there are 4 seals. One for each spark plug hole. Get yourself (or your buddy) a valve cover gasket kit.
Probably want to get new plugs too. They're probably fucked.
Old Jul 19, 2007 | 04:30 PM
usdmEHboy's Avatar
Default Re: oil in spark plug hole? (TEGGSRB18C1)
yea we were thinking it was the seals but wanted a second opinion...anyone else back up his answer?
Old Jul 19, 2007 | 05:07 PM
Sam92Teg's Avatar
tube seals for sure
Old Jul 19, 2007 | 05:08 PM
Lb1atx's Avatar
yeah it's your seals had the same problem but new seals oil went bye bye
Old Jul 22, 2007 | 11:40 PM
civic08's Avatar
Default Re: (Lb1atx)
how hard is it to change them out
Old Jul 23, 2007 | 01:00 AM
lsvtek's Avatar
Default Re: (civic08)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic08 &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to change them out</TD></TR></TABLE>
really simple.
And yes it is your seals that are bad
Old Jul 23, 2007 | 01:05 AM
Max500's Avatar
pull your valve cover, turn upside down, you will see 4 rubber seals around the spark plug holes.
Old Jul 23, 2007 | 09:08 AM
IZEONLI's Avatar
HEY GUYS I'M A NEWBIE JUST JOINING U GUYS I'M A HONDA TECH, AND I DRIVE A 92 TEG. 2 ANSWER UR QUESTION THER ARE SEALS CALLED LOWER AND UPPER SPARK PLUG SEALS. THAT PREVENT THAT FROM HAPPENING REAL CHEAP AND EASY TO INSTALL. BUT U SHOULD REPLACE ALL OF THEM .
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
premo_si
Jan 23, 2008 08:57 PM
matryx
Dec 15, 2007 01:18 PM
vltnolia
Feb 24, 2007 08:05 AM
screech
Jul 13, 2003 12:44 PM
