del sol key cylinder safety lock
Old Jul 19, 2007 | 04:13 PM
9395delsol's Avatar
Default del sol key cylinder safety lock
The key cylinder on the column of my 93 del sol was damaged when it was stolen, but I repaired it. When I put the key in the ignition it will only turn over in nuetral. When I go to take the key out, it will not turn all the way off to remove the key unless I disconnect the battery. I'm sure there is some kind of interlock but I don't know where it is or how it works. Can anybody help?
Thanks
Old Jul 19, 2007 | 04:40 PM
9395delsol's Avatar
Default Re: del sol key cylinder safety lock (Sandro)
The ignition cylinder is OK the only part that was damage was the part that wraps around the steering column. I used some JB weld to put the pieces back together.
dadsdelsol
May 23, 2016 09:33 AM
red99tegra
Sep 9, 2009 02:29 PM
k0rupt_ed
Sep 15, 2007 01:37 PM
EgSalad
May 12, 2007 08:51 AM
