ARM REST on doors crinkle???
Old Jun 9, 2002 | 07:29 PM
DeDonDeRosa's Avatar
Default ARM REST on doors crinkle???
on my gsr with black interior on the arm rests part they seem to get like a crinkle line in them and i have seen this happen to other black interiors can someone tell my why this happens and if possible how to fix it ???
thanks alot
Old Jun 9, 2002 | 07:36 PM
Sh!+F@ce's Avatar
Default Re: ARM REST on doors crinkle??? (DeDonDeRosa)
Don't know what causes it but my black interior teg is doing the same thing. Just pretend it isn't there. .... nope that didn't work it's still there
Old Jun 9, 2002 | 07:42 PM
JL 74's Avatar
Default Re: ARM REST on doors crinkle??? (****F@ce)
I have seen those crinkles on older Integras. I guess it is common.
Old Jun 9, 2002 | 07:44 PM
94acurals's Avatar
Default Re: ARM REST on doors crinkle??? (jl74)
yea my friends 97 has it, but my 94 doesnt.....
Old Jun 10, 2002 | 02:32 AM
PYITR821's Avatar
Try a blow dryer. Heat the crinkled area up a little and try and straighten it out. Let me know if it works.
Old Jun 10, 2002 | 05:53 AM
smeister's Avatar
If there is a crinkle in your door panel the plastic piece supporting the elbow rest on the door panel may be broken or cracked. I've had mine crack and wrinkled. HTH
Old Jun 10, 2002 | 09:44 AM
IC x Prince's Avatar
New User
Default Re: ARM REST on doors crinkle??? (smeister)
mine is oing it too...its when you lean on it...so i just stop leaning on it...i guess i'm just slowing the process down
Old Jun 10, 2002 | 10:24 AM
PoWeRBaN_PaNdA's Avatar
i have this problem too i justed took the door panels off and taped it where it was broken chicano fix
Old Jun 10, 2002 | 01:14 PM
JCushing's Avatar
this happens on litterally every del sol there is. look into it on a del sol forum/club. see what kinda options you have
Old Jun 10, 2002 | 02:53 PM
o_Rage_o's Avatar
Default Re: ARM REST on doors crinkle??? (JCushing)
cracked support, same happend to me, take out the door panel, fix it, blow dry a little to flatten and it should stick.
-Rage
Old Jun 11, 2002 | 05:26 AM
Default Re: ARM REST on doors crinkle??? (o_Rage_o)
i tryed the hair dryer thing only for lke couple min and if you get it heated up enough just get something to hold it down i got a section of it out i have to play with it some more
u just need patients
Old Jun 11, 2002 | 07:10 AM
bamaTeg's Avatar
New User
haha, mine has been doing this also recently. I have a wrinkle and it pops when I set my boney elbow on it...not gonna fix it though.
Old Jun 11, 2002 | 08:38 AM
Scary1109's Avatar
mine too, i'll try a hair drier tonight.
-Scary
Old Jun 11, 2002 | 09:05 AM
IntegGirlRacer's Avatar
Default Re: ARM REST on doors crinkle??? (Scary1109)
my 96 did it....i hope my 01 doesnt start to do it.
Old Jun 11, 2002 | 01:09 PM
spiritedb18c1's Avatar
What year is your GSR? Is it still under warranty?
The same problem happened to my 96 GSR. It happened around 97, and I remember that quite a few other integras had the same problem. I took the car back to the dealership and they fixed it under warranty. If your car is still under warranty, try going to the dealer and see if they'll do it under warranty. HTH
Spiritedb18c1
Old Jun 11, 2002 | 01:28 PM
legendboy's Avatar
Default Re: ARM REST on doors crinkle??? (spiritedb18c1)
It usually happens when a car is hit in the side and the door bends. Ususlly it does not get replaced but the bend is still there..
Old Jun 11, 2002 | 04:44 PM
SIK IN DA HED's Avatar
New User
Default Re: ARM REST on doors crinkle??? (legendboy)
i got that same thing on my side. i just pretend it isnt there.
austinkli
10
May 27, 2008 08:58 AM
saikou
Apr 1, 2007 02:44 PM
Dc2LsSE
Dec 16, 2004 07:06 PM
DeDonDeRosa
Jun 6, 2003 08:00 AM
Zulu888
Feb 13, 2002 11:35 PM
