what should I get next?
alright, so far, i've done intake and cat-back exhaust for performance, and swaybars for handling. What should I do next? I have roughly $800 to spend, and I want your suggestions. Thanks
isn't that closer to 900+? The max that I have would be about $850
ur max is $850... you can either try to see if you can get a good price on some coilovers..
or
Koni Yellows - approx $500-550 (shop around)
Eibach sportlines - approx $180-200 (shop around)
Brembo blanks - approx $28/ea for front rotors..
you can get these from http://www.collettimotorsports.com brembo OE Blank/solids.. fronts $28/ea.. rears $20/ea (click on "specials")..shipping = $10/ea (2 fronts would be $76 shipped)
Hawk HPS pads - approx $80/set front.. (same place http://www.collettimotorsports.com)
another place that has the Brembo blanks is http://www.performancemotorcars.com its like $34/ea for the front brembo rotors.. however on orders over $50.. shipping is free.. so it comes out to $68
OR
KYB AGX - approx $320-340
Eibach prokit - approx $220
Kumho Exsta Supra 712 or Falken Azenis (I'm assuming you have the stock 15" wheels.. so tire would be 205/50/15) - approx $70/tire...
if you shop around for good pricing.. there is a few options for your $850 well spent..
also yes you can do some engine/motor mods for $850 also.. but I think you should work on handling and braking well so you can control the car before you introduce more speed
good luck on your quest for new parts = )[Modified by GSRaCeRbOI, 12:44 AM 6/10/2002]
i agree w/ the others..... but if you want to hold off on that..then get your self a some cams...toda, skunks, or ctr/itr cams...if you get ctr/itr cams..then you still have enough for a skunk2 manifold!
White Lotus
Sep 19, 2006 11:44 AM
The Nookers
Nov 8, 2005 12:00 PM
SiCivic_02
Nov 5, 2002 05:35 PM
