Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Oil Gush From Behind The Motor When Cranking
Old Jul 19, 2007 | 10:59 AM
PoMoNa_909_eM2's Avatar
Default Oil Gush From Behind The Motor When Cranking
i was driving to visit my cuzzin in northern california on friday night..... all of a sudden there was a big rattling sound from the bottom of the car....next thing the check engine light came on after two flashes the car just shuts off gas pedal locked but i can still break a little..... and then i pulled over on the side of the freeway.....i try to start the engine...yes it still cranks but as soon as i gas the car it turns right on but a big gush of oil leaks through from behind the motor spilling all over the bottom of the car onto the freeway.....what can be the problem here? any help or opinion would be great...thanks................
Old Jul 19, 2007 | 11:03 AM
jivi's Avatar
Default Re: Oil Gush From Behind The Motor When Cranking (PoMoNa_909_eM2)
might be an oil drain plug came out from the pan...or it's loose...maybe.
Old Jul 19, 2007 | 11:10 AM
mucter's Avatar
sounds like the oil filter is loose or fell off.
Old Jul 19, 2007 | 11:14 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (mucter)
Ouch, sounds expensive whatever it is. Let's hope you didn't spit a rod out
Old Jul 19, 2007 | 11:30 AM
should i just swap the motor to another d17? or go K?
Old Jul 19, 2007 | 11:50 AM
Boilermaker1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PoMoNa_909_eM2 &raquo;</TD></TR><TR><TD CLASS="quote">should i just swap the motor to another d17? or go K?</TD></TR></TABLE>
Well.... do you have $300 or $5000?
Old Jul 19, 2007 | 11:53 AM
jivi's Avatar
O' man, you came up with the best solution I think LOL, a K swap
Old Jul 19, 2007 | 12:16 PM
Default Re: Oil Gush From Behind The Motor When Cranking (Boilermaker1)
yeah i got it.....but just wanna know if the k will be worth it for that money.......
Old Jul 19, 2007 | 01:36 PM
da1lydr1ver's Avatar
i think your oil filter might have came loose like mentioned above. most likely, your engine is toast.
is a K swap worth it? well, thats more of a personal question. you will definately be dropping a pretty penny to get the k swap done correctly, plus a lot of downtime for your car.
Old Jul 19, 2007 | 01:54 PM
thanks for the help.....
Old Jul 20, 2007 | 08:43 AM
Curiouz_G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boilermaker1 &raquo;</TD></TR><TR><TD CLASS="quote">
LOL
Old Jul 20, 2007 | 10:50 AM
Tadehi's Avatar
Schumacher '10 WDC
Default Re: Oil Gush From Behind The Motor When Cranking (Curiouz_G)
So what happened?
Old Jul 20, 2007 | 11:28 AM
fventura03's Avatar
i loffled a little
Old Jul 20, 2007 | 11:41 AM
DsevenEm2's Avatar
yea so my engine started gushing oil....
do you have money for a k
yea...
problem solved.
Old Oct 12, 2010 | 08:45 PM
92b16si's Avatar
bringing it back from the grave because the same thing happen to me today. i cought it on time and not alot of oil gushed out. what did it en up being?
Old Oct 13, 2010 | 07:13 PM
99blackcivicSi's Avatar
3 year old thread...your bringing it back up for the reason it could have spit a rod, oil filter fell off, drain plug fell out, curb shot on the oil pan...
get under the car and look if you didn't lose a lot of oil i doubt the drain plug fell out and i doubt the filter fell off, i'd prepare for the worst, get under the car and look.
kixcrx
18
Jan 15, 2007 12:00 PM
Robstunner4
May 8, 2005 03:28 AM
Campee
13
Dec 14, 2003 09:59 PM
96hb
Sep 14, 2003 07:57 PM
GQ-Lude
Aug 13, 2002 11:06 AM
