car wont start
Old Jul 18, 2007 | 11:56 PM
trix are for kids's Avatar
Default car wont start
bone stock gsr, good spark, fuel is good, oil is good, ecu is good, new battery, alarm de-installed, compression over 100 in all cylinders. motor will crank, but wont turn over
little history, blew the ignition coil and had it replaced, ran fine until it died again on the road. replaced coil again, with new igniter as well. new cap/rotor, spark plugs/wires replaced before 1st coil blew. car wouldnt hold idle and finally died at my friends house.
any help would be greatly appreciated, thanks
Old Jul 19, 2007 | 08:51 AM
DC2R_JOE's Avatar
Default Re: car wont start (trix are for kids)
You said over 100compression? So did you actually do a compression test?
Old Jul 19, 2007 | 10:54 AM
Default Re: car wont start (DC2R_JOE)
yes sir. i towed it to a shop who said there was 0 compression and my friend didnt believe them, so he did one himself and saw that compression was good. we are all stumped on what this could be.
Old Jul 19, 2007 | 12:07 PM
hard charging 929's Avatar
I know you said over 100 on the compression check but what did it actually come in at. Should be up near or some even ove 200. Also, do a leak down check.
How did you check for fuel and spark?
hmtcrxsir
Jul 10, 2007 11:41 AM
Bngo731
Jun 5, 2006 02:42 PM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
aVstAr
Jan 21, 2003 06:24 AM
mugenracer
May 19, 2002 02:29 PM
