Car wont rev past 4k rpm
Old Jul 18, 2007 | 10:32 PM
dcdcdc's Avatar
Default Car wont rev past 4k rpm
so out of the blue's the car wouldnt pass 4k rpm and would feel sluggish like the car was being pulled back. in neutral, it revs fine but in any gear while driving it wont let the car pass 4k rpm. any ideas to what is happening here?
car is a 2002 civic hatch si
Old Jul 19, 2007 | 01:08 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: Car wont rev past 4k rpm (dcdcdc)
Sounds like you're in limp mode for whatever reason. I think if you go to Autozone or w/e the hell it's called, they can give you a code with their snazzy machine or something.
Old Jul 19, 2007 | 04:13 AM
daddy's Avatar
Default Re: Car wont rev past 4k rpm (EM2_UK#1)
change the oil. mine did this about a month ago and that fixed it
Old Jul 19, 2007 | 04:25 AM
Newborn_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcdcdc &raquo;</TD></TR><TR><TD CLASS="quote">
car is a 2002 civic hatch si</TD></TR></TABLE>
Ah, i didn't see this the first time. Reading properly ftw
Try here https://honda-tech.com/zeroforum/32
Old Jul 19, 2007 | 08:57 AM
wishbear's Avatar
it could be that your oil is too dark or your cat back is messed up
Old Jul 19, 2007 | 09:11 AM
DiMpL3s's Avatar
Default Re: Car wont rev past 4k rpm (wishbear)
take it to honda
TTT
Old Jul 19, 2007 | 12:03 PM
KOREAN's Avatar
Default Re: Car wont rev past 4k rpm (DiMpL3s)
oil change.
/thread
Old Jul 19, 2007 | 12:15 PM
2fasttypes's Avatar
idk i had the same problem w/my base rsx it wouoldnt go past 4rpm's and in neutral it would be fine....i suggest u let it sit overnite in ur driveway that pretty much worked for me and never happened again or u can just take it to the dealer
Old Jul 19, 2007 | 12:26 PM
lucky4586's Avatar
Default Re: Car wont rev past 4k rpm (2fasttypes)
you could have a clogged cat or muffler that happened to my gf's car and it took me like a month to figure it out.
Old Jul 19, 2007 | 03:15 PM
dcdcdc's Avatar
Default Re: Car wont rev past 4k rpm (lucky4586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lucky4586 &raquo;</TD></TR><TR><TD CLASS="quote">you could have a clogged cat or muffler.</TD></TR></TABLE>
what do you mean 'clogged'? like theres carbon build inside? i will definitely try the oil change since it worked for a few people.
Old Jul 19, 2007 | 08:12 PM
dcdcdc's Avatar
update, i did the oil change and wow it worked! now can someone explain to me how/why the car knew that the oil was bad and put it in 'limp' mode. thanks to all that replied.
Old Jul 20, 2007 | 08:24 AM
lucky4586's Avatar
Yes carbon build up in the cat, and i would also like to know how the car knew it needed new oil... or was it just really low on it? how many miles where on the oil when you changed it?
Old Jul 20, 2007 | 10:07 AM
dcdcdc's Avatar
hahah 5k since the last time. but hey anyone know how the car knew??
Old Jul 20, 2007 | 10:39 AM
lucky4586's Avatar
how much oil did it have in it? was it low on oil at all? if so maybe by oil psi.
Old Jul 20, 2007 | 12:00 PM
daddy's Avatar
honda programmed the computer so it knows you need an oil change every 3k miles. if the computer didnt get reset the last time or you go way over the engine keeps track of the milage and when it hits a certain number (im thinking 5k cuz mine was at that milage too) it starts to 'protect' the engine by limiting revs. it might sound like a pain in the *** but if it helps protect my engine i'll deal with it!
Old Jul 21, 2007 | 02:19 PM
dcdcdc's Avatar
Default Re: Car wont rev past 4k rpm (03turboem2)
thanks for the answer.
Old Jul 22, 2007 | 02:02 PM
Davanca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 &raquo;</TD></TR><TR><TD CLASS="quote">honda programmed the computer so it knows you need an oil change every 3k miles. if the computer didnt get reset the last time or you go way over the engine keeps track of the milage and when it hits a certain number (im thinking 5k cuz mine was at that milage too) it starts to 'protect' the engine by limiting revs. it might sound like a pain in the *** but if it helps protect my engine i'll deal with it!</TD></TR></TABLE>
This is not true. The reason this is not true is because, we don't have a oil life counter system like the newer cars have. Like on the TL, Malibu, BMW's, etc. where you have to reset the computer after every oil change just so the computer reads the oil life correctly. We do not need to reset our computer after every oil change.
The reason his engine went into limp mode was because the ecu recognized that the oil pressure was low and it won't be safe for high rpm operation. Thats why before you reach the point of limp mode, you will notice that vtec stops working when you over due for an oil change. You need oil pressure for vtec to work properly. When your seriously due for an oil change limp mode will occur.
Old Jul 23, 2007 | 06:41 AM
lucky4586's Avatar
Default Re: Car wont rev past 4k rpm (Davanca)
Thats what I thought but wasn't sure.
Old Jul 24, 2007 | 02:15 PM
3rdgencrx's Avatar
you guys don't change your oil until you have problems huh?
Old Jul 25, 2007 | 05:48 AM
daddy's Avatar
Default Re: (3rdgencrx)
i change mine every 5000 miles cuz i run synthetic. when i had the problem with the revs cutting out i had been on a long trip for work and had racked up lots of miles fast and hadnt had time to change the oil yet.
2001civic2001
Honda Civic (2001 - 2005)
Apr 29, 2016 11:10 AM
davidfillups
24
Sep 8, 2008 09:55 PM
B18C1 '96 Coupe
27
Jan 26, 2006 02:32 PM
wpsadmin
Nov 14, 2004 06:58 PM
obd1gsr
Dec 23, 2003 10:31 PM
