car won't start h22 accord no spark
Old Jul 18, 2007 | 09:33 PM
b18 EK9's Avatar
Default car won't start h22 accord no spark
ok i tested the distributo in another car and the dist is good the car won't start what do i do? where do i check it has fuel thats not a prob there is no spark???????
Old Jul 18, 2007 | 11:56 PM
dleccord's Avatar
did you do a leak down test? does the motor turn?
Old Jul 19, 2007 | 12:17 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: car won't start h22 accord no spark (b18 EK9)
check your main relay!
Old Jul 19, 2007 | 07:58 AM
b18 EK9's Avatar
Default Re: car won't start h22 accord no spark (I got the CD5 Jeebies!)
it has good compression and the timing belt is right on the money!!!!
Old Jul 19, 2007 | 08:20 AM
hondatuningboi96's Avatar
what about the coil?
Old Jul 19, 2007 | 08:42 AM
hurleyint's Avatar
Default Re: car won't start h22 accord no spark (hondatuningboi96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondatuningboi96 &raquo;</TD></TR><TR><TD CLASS="quote">what about the coil?</TD></TR></TABLE>
This was my problem when I did my swap.
Old Jul 19, 2007 | 11:19 AM
b18 EK9's Avatar
its not the distributor
Old Jul 19, 2007 | 01:28 PM
joshkwong's Avatar
Default Re: (b18 EK9)
maybe its the ignition wires..coming from the distributor..or bad plugs?
Old Jul 19, 2007 | 02:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I got the CD5 Jeebies! &raquo;</TD></TR><TR><TD CLASS="quote">check your main relay! </TD></TR></TABLE>
ahem?
Old Jul 19, 2007 | 03:59 PM
b18 EK9's Avatar
the main relay is good i took it off and tested it and its good and the wires that go to the relay have power and there is no power to the ecu or the check engine light does not turn on can it be the pgm fuel injection relay you think come on i need some help here
Old Jul 19, 2007 | 08:01 PM
hondadude's Avatar
Ground wire at the T-stat housing
Old Jul 19, 2007 | 10:54 PM
b18 EK9's Avatar
Default Re: car won't start h22 accord no spark (hondadude)
I just fixed it I wish someone would have told me the ground on the thermostat housing earlyer cause that was the proble the wire was conected but the wire was burn somewhere down the line thanx guys couldn't of had done it without your help
Old Jul 20, 2007 | 12:11 AM
dleccord's Avatar
what do you mean burned down somewhere the line?
Old Jul 20, 2007 | 10:46 AM
Default Re: (dleccord)
haha that's funny
Old Jul 20, 2007 | 02:33 PM
b18 EK9's Avatar
Default Re: (hondatuningboi96)
yeah what happend is that they brought me a accord with a h22 turbo swap and they tried wiring a v-tec control and alot of other stuff and the stuff was wired in incorrectly and coused alot of shorts and its all good ready to put the hondata on it to see what it can do
dan89crxsi
Feb 10, 2007 02:44 PM
koreachangsu
Aug 16, 2006 03:20 PM
edsymister
Jul 27, 2006 06:31 PM
sohc90rex
16
Dec 21, 2005 09:20 PM
ironcheftony
Sep 22, 2003 06:53 PM
