"reversible" puller fan?
Old Jul 18, 2007 | 09:16 PM
cpmike's Avatar
Default "reversible" puller fan?
im looking for a 10" pusher fan.
the only <$100 priced ones are generic "reversible" puller fans. but if you look at the shape of the blades, it obviously wouldnt be working as efficiently if it were used as a pusher.
are there any cheaper pusher fans out there, or am i gonna have to shell out $150 for a fan
Old Jul 19, 2007 | 07:35 AM
Relic1's Avatar
take generic puller fan, reverse the polarity and flip the blades over.
now it's as efficient as it was the other way.
Old Jul 19, 2007 | 08:04 AM
Flashmn's Avatar
Default Re: (Relic1)
you wouldnt even have to flip the blades, they should be just fine with the polarity switched.
Old Jul 19, 2007 | 09:44 AM
ndogg's Avatar
Default Re: "reversible" puller fan? (cpmike)
flip the blade too man. b18bturbo has them for like $50 shipped.
Old Jul 19, 2007 | 02:36 PM
cpmike's Avatar
Default Re: "reversible" puller fan? (ndogg)
most sites i saw only mentioned reversing polarity and nothing about flipping blades, which that alone is not a viable option for me.
i figured they were a premoulded fan/blade assy mounted to the motor, do some actually come with removable, flippable blades?
ill get in touch with b18bturbo, thanks.
Old Jul 19, 2007 | 02:49 PM
Relic1's Avatar
everyone I've seen has a nut that holds the blades to the armature of the motor. 8mm usually.
Old Jul 20, 2007 | 11:55 AM
Bakeoff's Avatar
If the blades are straight, it's not going to matter.... Just reverse the polarity.
There is one vendor in the marketplace that has cheap fans that I've run for a long time with no problems.
I'm currently running two in a pusher puller configuration.
Old Jul 20, 2007 | 04:36 PM
cpmike's Avatar
Default Re: (Bakeoff)
yeah, just most items i were seeing had curved blades.
anyway i hit up b18bturbo / vsracing.com (probably who you are talking about) for one for $35 shipped, and it has reversible blades. flippin sweet, thanks peoples.
KamalHonda
May 30, 2018 12:50 PM
slow sol
Mid-Atlantic (Sales)
Sep 18, 2009 04:58 AM
maxogsr
24
May 11, 2009 07:40 AM
