Oil pump install
When installing the oil pump it says to apply liquid gasket to the pump and install. This means rtv or is there something else i should use ? There is no gasket involved here correct besides the seals on the pump itself. I am talking about sealing the pump to the block. Thats how it seems in the book however just seems kind of strange to me.
Im looking on page 8-15 on the factory service manual.
You're building an engine, and you're complaining Hondabond is expensive?
I only use Hondabond HT, it's much easier to work with than Hondabond 4, IMO. Also, I've never had anything that worked as well as Hondabond HT for me. It also cleans a ton easier than most RTV I've used.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 »</TD></TR><TR><TD CLASS="quote">hmmm hondabond is $$ does it really matter if i use that or permatex gray ? Is that an rtv or is it called just permatex gray ? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 »</TD></TR><TR><TD CLASS="quote">You're building an engine, and you're complaining Hondabond is expensive?
i only use hondabond. Basically its alittle more but ive had good experiences with it and personally thats worth the extra few dollars knowing that I used the right ****
Corksil
Jan 25, 2011 10:36 AM
Grand
May 9, 2005 11:09 AM
