15 inch steel wheels
Also if you get the 'si' style hubcaps to go with them, they look pretty good. Can't really explain them, they're just the 7 spoke covers that came stock on the 01-05 civics.
I know I am revisiting an old thread.
I am researching 15 inch steelie options for my 5th gen ('95) civic. I know hub size 56.1mm so that is a concern.
I read the 09-14 Honda Fit is using 15" 4x100 steelies. I was wanting to find out if the hub hole size is big enough to fit the 56.1mm requirements of my civic.
I'm assuming the 01-05 civic steelies meet the minimum hub requirements?
Ideally, finding 15" steel wheels with 4x100 that doesn't require spigot (hub centric) rings would be ideal.
Can anyone confirm what the best match would be? I am in Canada so the CDM Acura 1.6 EL is also an option.
Thanks in advance.
Thanks in advance.
Factory Honda steel wheels have ball-style lug nut seats, and thus do not require hubcentric rings unless they're damaged or worn out (rarely ever happens) as long as you have the appropriate ball-style lug nuts (factory) to match.
Any more modern Civic (as long as its 4x100) will fit the bill, as far as fitting your car. The Fit will work as well, but keep in mind that you'll need a 2010+ Fit wheel, since the older ones are 14" (these are also 56.1mm hub bores, just like almost all 4x100 Civics).
v-attack
Dec 17, 2012 12:29 PM
