Dist. rotor stuck on shaft
Old Jul 18, 2007 | 03:39 PM
dcdcdc's Avatar
Default Dist. rotor stuck on shaft
Are there any ways out there to take this metal piece of the rotor off of the shaft. I completly broke off all the plastic parts of the rotor doing the replacement and can't get this piece off. Theres rust around it and I have let it soaked in PB blaster for awhile and still cant pull it off. TIA
Here are some pics to help visually:
Old Jul 18, 2007 | 03:50 PM
B16b-EJ8's Avatar
Default Re: Dist. rotor stuck on shaft (dcdcdc)
Did you happen to remove the retaining screw in the side?
Old Jul 18, 2007 | 03:55 PM
dcdcdc's Avatar
Default Re: Dist. rotor stuck on shaft (B16b-EJ8)
haha yes i have, that was a bitch to take out too!
Old Jul 18, 2007 | 03:59 PM
B16b-EJ8's Avatar
Just checking...keep prying i has to come off eventually, tap the rotr with a rubber mallot lightly then turn and pry tap turn and pry...repeat if necessary. Good luck
Old Jul 18, 2007 | 04:37 PM
slowcivic2k's Avatar
You can try heating it up with a lighter or a small propane torch, its your best friend for things that are a very tight fit, like broken distributor rotors or transmission bearings.
Old Jul 18, 2007 | 04:59 PM
Crazydave's Avatar
Default Re: Dist. rotor stuck on shaft (slowcivic2k)
Impact screw driver on the set screw.. make sure to support the shaft so that you don't damage it
Old Jul 18, 2007 | 05:04 PM
dcdcdc's Avatar
Default Re: Dist. rotor stuck on shaft (Crazydave)
maybe heating it up might work. as for the impact screwdriver, its not the screw im having trouble with (already dealt with) its the metal piece that goes on the shaft.
Old Jul 18, 2007 | 05:21 PM
dcdcdc's Avatar
thanks to all that replied, got it off
Old Nov 29, 2015 | 01:54 PM
cdn_cajun's Avatar
I'm having the same problem. How did you get it off? I've tried some heat from a heat gun with no luck. Been soaking all day with WD-40 and penetrating oil. Also tried pushing further on with a socket/hammer to break the rust. It went further on but will not pull off. Can't get a battery terminal puller on good enough to try pulling it off. Any other suggestions other than to let it continue to soak? Was someone able to take off with a dremel?
Old Nov 29, 2015 | 02:32 PM
cdn_cajun's Avatar
Finally got it off. After soaking for a while I used a 3ft long prior bar with a block of wood to protect the distributor. Took a lot of pressure and it snapped off. I thought I had shattered it but it came off clean. I cleaned up the shaft with a emory sandpaper and used a little of anti-seize before re-assembl.
Old Dec 6, 2015 | 02:33 AM
angrysmileyface's Avatar
I have found ind the past to remove stubborn rotor metal rings that are stuck to take a dremel, cut a small notch and using a screwdriver pry the notch apart. Ring will then slide off. This is like removing a bearing race off a wheel hub
belairbrian
10
Mar 1, 2013 06:14 PM
dcdcdc
Jul 18, 2007 05:22 PM
Homesickelian
Dec 9, 2006 09:20 AM
blackls
Jul 5, 2001 07:31 PM
Ubermensch
Jun 30, 2001 04:48 PM
